Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Build date code 1967
Old Nov 17, 2019 | 06:42 PM
ls5bigblock's Avatar
ls5bigblock
Default Build date code 1967
Hi I would like to know what the build date is on this 1967
I will attach some pix
C5
G51
Thank you
Old Nov 18, 2019 | 11:06 PM
gbvette62's Avatar
gbvette62
"L 10 6" is the casting date, December 10, 1966, but I'm having a hard time figuring out where that date is. Is it the block?
67 Corvette VIN 08492 was built approximately January 19, 1967. The upper left corner of the trim tag should have a letter and number indicating the body build date, but your photo only shows the right side of the tag, so I can't match that to the VIN.
It's hard to read the full stamp pad, but it appears the engine assembly date is 0112, January 12, 1967. I can't comment on the authenticity of the pad, except to say that it's hard to tell if there are broach marks present, and the quality of the photo makes it difficult to judge the engine stamp/suffix code.
The final casting date shown is September 20, 1966 "I 20 6".
Old Nov 24, 2019 | 06:54 PM
provette67's Avatar
provette67
"L 10 6" is the date on the cast iron intake pictured
Old Feb 6, 2020 | 03:53 PM
93RubyRedCoupe's Avatar
93RubyRedCoupe
cast iron intake, which means its a 390hp car. IM code on the pad means it's a 390hp, 4 speed SMOG car. Nice.
Old Feb 8, 2020 | 12:21 PM
Silver surf's Avatar
Silver surf
I have a 1967 coupe with a 427/435 engine. The date code difference between my car and engine is 120 days which seems very unusual but I looked at the 427 survey in Noland's book
and it appears that several of the cars in my VIN range had 120+ days between the engine date code and VIN. My car has A.I.R. (K19), I'm wondering if they built a batch of engines and took a while for the demand to catch up?
Old Jun 29, 2025 | 02:31 PM
bhb67's Avatar
bhb67
5th Gear
can someone tell me what is considered a period correct motor for a 1967 corvette.
Thanks.
Old Jun 29, 2025 | 08:29 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
it would be best to start a new thread. but in short a period motor would be a engine that has a casting date before the cars build date
To Build date code 1967
