Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Alternator positive pole boot
Old Dec 13, 2002 | 03:53 PM
LAWTON54's Avatar
LAWTON54
Default Alternator positive pole boot
What is the correct type boot for a 1968? Where can I find one? Are all the same through 1982?
Old Dec 13, 2002 | 05:16 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: Alternator positive pole boot (LAWTON54)
Not 100% sure of this, but midyears use the boot with the "X" on the back. I assume 68's MIGHT use the same. Repro boots are smooth....no "X" ribs. Chuck
Old Dec 13, 2002 | 09:05 PM
LAWTON54's Avatar
LAWTON54
Default Re: Alternator positive pole boot (Chuck Gongloff)
Chuck, thanks for your reply. Are they black or grey?
Old Dec 14, 2002 | 05:36 AM
Chuck Gongloff
Again, I'm no 68 expert, but I've only seen black. Maybe the gray you've seen is a faded, chalky black. There are probably several million of these "correct" boots laying in junkyards all over the USA. :) Chuck
Old Dec 14, 2002 | 09:51 AM
Guest
Guest
Posts: n/a
FWIW, here is a pic of my '67 alternator with a new Lectric Limited harness. It's hard to make out, but the lettering on top of the boot says....HI 508. Not sure how correct it is, but it's good enough for me.
http://temp.corvetteforum.net/classi...ternator.1.jpg
Old Dec 14, 2002 | 11:02 AM
LAWTON54's Avatar
LAWTON54
Chuck. thanks for the information.
Old Dec 14, 2002 | 11:16 AM
LAWTON54's Avatar
LAWTON54
Default Re: Alternator positive pole boot (FXT)
FXT, thanks for the picture and the information. Lectric Limited is in the Chicago area, I am going to call them. They share a building with Chicago Corvette and they have a small junk yard in the back.
Old Dec 14, 2002 | 11:37 AM
Chuck Gongloff
Here's a pic of the alternator boot on my 63. Notice the cross or "X" pattern. This is the same boot as is on my 69, but since the alternator is rotated, it was easier to get a picture of the 63. I have the original wiring harnesses on both cars.
I do believe that this is the "correct" boot. I think Patrick's is a Lectric Limited generic replacement. Chuck
[Modified by Chuck Gongloff, 11:41 AM 12/14/2002]
[Modified by Chuck Gongloff, 11:42 AM 12/14/2002]
Old Dec 14, 2002 | 12:30 PM
Guest
Guest
Posts: n/a
Chuck, there is an "X" or cross pattern on mine, although you may not be able to see it from the pic. Oh well, I guess I'll have to live with a generic repop, don't have St. Louis air in my tires either!! :lol:
[Modified by FXT, 12:31 PM 12/14/2002]
Old Dec 14, 2002 | 01:06 PM
LAWTON54's Avatar
LAWTON54
Chuck, thanks for the picture, that is what I had before it fell off. It was very distorted and discolored.
Old Dec 14, 2002 | 03:59 PM
GaryS's Avatar
GaryS
Lawton54, am I to assume that your boot is no longer good? I just went down to the basement in my "bucket of bolts" and, knowing that I had a rubber boot, I pulled it out. It has the X on it andis like new! It is a junkyard "special". Yours if you want it.
Gary
Old Dec 14, 2002 | 04:36 PM
LAWTON54's Avatar
LAWTON54
Default Re: Alternator positive pole boot (GaryS)
Gary,
That will be great, I will email my home address.
Thanks,
Al
Old Dec 14, 2002 | 07:46 PM
Chuck Gongloff
Tsk, tsk, Patrick. Did you know that you'll lose about ONE whole point for that incorrect boot? :D Also, rumor has it that factory correct air WILL be available soon. Just send in the build date of your car, and you'll get "correct" air with JUST the right amount of pollen and other "period correct" air pollutants. Chuck
Old Dec 15, 2002 | 11:54 AM
JohnZ's Avatar
JohnZ
It will also have to contain at least 20ppm of fiberglass dust if it's "real" St. Louis air; samples will be taken and checked via scanning electron microscopes and gas spectro-chromatographs :D
Old Dec 21, 2002 | 12:44 PM
LAWTON54's Avatar
LAWTON54
Gary, received the boot a few days ago, thanks again. It is in great shape.
To Alternator positive pole boot
