Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
bench testing 68-69 ammeter gauge
Old Dec 21, 2002 | 10:56 PM
MELVIN's Avatar
MELVIN
Default bench testing 68-69 ammeter gauge
Could someone give me a VERY simplified wiring guide or simple way to bench test the ammeter gauge on my 68. As of now, its stuck all the way to the right, wether the ignition is on or off, or engine is running
Id like to check it before I replace it
Old Dec 22, 2002 | 11:12 AM
LAWTON54's Avatar
LAWTON54
Default Re: bench testing 68-69 ammeter gauge (MELVIN)
All you need to do is check with an ohmmeter. If the circuit is open, the guage will not function. You can open the guage, unwind the coil, measure the length of the wire, rewind using same guage wire. I rebuilt mine and it works great.
Old Dec 22, 2002 | 12:22 PM
MELVIN's Avatar
MELVIN
Default Re: bench testing 68-69 ammeter gauge (LAWTON54)
Will do, thanks
To bench testing 68-69 ammeter gauge
