Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
BB Pad Numbers/Letters
Old Jan 4, 2003 | 05:51 PM
66BBCoupe's Avatar
66BBCoupe
2025 C3 ('68-'73) of the Year Winner - Unmodified
2023 C1 of the Year Winner - Modified
2021 C2 of the Year Winner - Unmodified
Default BB Pad Numbers/Letters
I've noticed on what appear to be original Corvette Big Block Vin Pad examples that in the Tonowanda build date section - it seems to mix letters and numbers. For example, TO22I6 IP (Feb 21st 1966) where the 21st day second digit is the letter I - where you would think a numeral 1 would be. I also checked an original Chevelle 427 LS6 and it evidenced the same usage. Was this common or consistant and what was the reason to mix it up like this? The judging manual does not seem address this.
Password:
Old Jan 4, 2003 | 07:25 PM
ED DINAPOLI's Avatar
ED DINAPOLI
Default Re: BB Pad Numbers/Letters (66BBCoupe)
I am not sure what the 65-66 Referemce Manual indicates , but the 70-72 Reference Manual says "It is not uncommon to find the numeral 1 stamped as the letter I." Hope this helps.
Ed
Old Jan 4, 2003 | 09:43 PM
wombvette's Avatar
wombvette
Default Re: BB Pad Numbers/Letters (ED DINAPOLI)
1 and I are used almost interchangably in the source production code, but not in the serial number.
Old Jan 5, 2003 | 12:09 AM
Red69's Avatar
Red69
My 69 BB has a TI2... vs T12... in the pad... I've alway wondered my self what was up... glad to hear its a common practice.
Old Jan 5, 2003 | 12:39 AM
66BBCoupe's Avatar
66BBCoupe
Default Re: BB Pad Numbers/Letters (wombvette)
Wombvette - would you know if the NCRS judges are all clued in on the interchangability factor when considering pad points?
Old Jan 5, 2003 | 04:32 PM
JohnZ's Avatar
JohnZ
Yes, they are (if they've been judging Mechanical for more than a week) - if not, they need more O.J. time :D
Old Jan 6, 2003 | 02:58 PM
Ironcross's Avatar
Ironcross
My 1966 427 engine reads TO 610 IP { June 10th, 427ci, 425/450hp. mt } :steering: :thumbs:
Old Jan 6, 2003 | 05:21 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: BB Pad Numbers/Letters (Ironcross)
On 63 and 64 pads, you'll COMMONLY see a strange looking "b" as the number "6". You'll also see the number "9" as the same strange "b" inverted. You'll also find the number "0" and the letter "O" used interchangeably. Experienced judges do know this. :) Chuck
Old Jan 9, 2003 | 11:46 PM
Juliet's Avatar
Juliet
Default Re: BB Pad Numbers/Letters (Chuck Gongloff)
I'll have to go look at some C2 pads. :yesnod: I haven't seen the B 6 9 thing in 68-72 but the 1/I and 0/O thing are really common on the sharks. :jester
To BB Pad Numbers/Letters
