Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
C2 window channels
Old Mar 4, 2003 | 12:55 PM
GregP's Avatar
GregP
Default C2 window channels
WARNING - ACTUAL FCR QUESTION !!!
In looking at my AIM and the various supplier catalogs I can't quite tell if the front "window channel" they sell is the whole piece shown in the AIM including the bolt etc that secures it at the bottom to the door inner skin, or if it is just a felt insert that goes into the rigid steel part. I'm planning to "fix" the vent window, but need the front glass rail. Can anyone tell me if the front "rail" is the same as the "channel", is it part of the vent wing assembly, or ???
Thanks - Greg
Old Mar 4, 2003 | 02:33 PM
JohnZ's Avatar
JohnZ
Default Re: C2 window channels (GregP)
The front glass channel (the "U"-section steel channel with the stud at the bottom) originally came as part of the "Vent Window Assembly". I think what you're seeing in the catalogs is the fabric insert with the chrome beading on the edges that is inserted into the run channel. Paragon lists the vertical front run channel (the steel part) in their catalog, NOS, with the price as "Call", and we know what that means :eek:
Old Mar 4, 2003 | 02:41 PM
GregP's Avatar
GregP
Default Re: C2 window channels (JohnZ)
Thanks John.
Anyone know what the cross-section dimensions of the steel window run is in case I need to "create" one that will hold the normal felt piece?
-Greg
To C2 window channels
