Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Horn Rebuild Kit
Old Mar 13, 2003 | 08:09 PM
RMS73's Avatar
RMS73
Default Horn Rebuild Kit
Any one know where I get the rivets and gaskets for the horn. Zip does not carry the simple rebuild kit anymore, and I don't want to pay for the metal diaphragms.
Roger
Old Mar 15, 2003 | 02:28 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Horn Rebuild Kit (RMS73)
Well I have come up empty, I searched all the links I have, and no luck.
Hopefully somebody can help you.
:seeya
Old Mar 15, 2003 | 08:33 AM
67's's Avatar
67's
I got one for my '69 Last year from my local GM Dealer did you try them?
Tom
Old Mar 16, 2003 | 01:13 AM
John McGraw's Avatar
John McGraw
Paragon will sell you the rivets and gaskets by themself. They do not advertize it, but they will. The rivets are about $.20 each, but I make my own gaskets now as the last few that I bought had shrunk and did not fit. I agree that the replacment diaphrams are junk! They are too thick and do not make as loud a sound as originals. I re-use originals whenever possible.
:seeya
Old Mar 16, 2003 | 01:59 AM
GDaina's Avatar
GDaina
Default Re: Horn Rebuild Kit (John McGraw)
when the horn doesn't sound, that means the diaphram gas gone south?
Old Mar 16, 2003 | 02:47 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: Horn Rebuild Kit (GDaina)
Good grammer there George.... :lol:
English man, speak english... :p:
Old Mar 16, 2003 | 06:34 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
If it doesn't "honk", could be several things. The diaphragm is only one of those items. Could be electrical...the coil/magnets, etc. Could be rust/dirt. The replacement diaphragms for both high and low are now "repro'ed" with the same thickness, whereas original diaphragms used one thickness for low, and a thinner for high. I think lows were .020 and highs were .015 inch. That's why often high note horns won't work with the repro diaphragms.
There's a real science to rebuilding these, as you not only have the mechanical and electrical elements, but you also have the "tuning" element. The rivets must be set like you're tuning a snare drum...with the same "tightness". Otherwise, the diaphragm won't vibrate correctly. Two of my friends, and Mason Dixon Chapter NCRS members have a side business rebuilding horns. They use original parts whenever possible. They are always buying swap meet horns to pirate for original parts. They had the rivets custom made and use a special press to install them. It's a labor intensive job. I've watched them do it. Chuck
Old Mar 16, 2003 | 01:55 PM
RMS73's Avatar
RMS73
To George:
Interesting comment about the diaphragm being bad and equating it to the south. Down south we would have said it went north.
Roger
Old Mar 16, 2003 | 08:23 PM
JohnZ's Avatar
JohnZ
Dennis Portka has been rebuilding Corvette horns for about 25 years, and it takes him about 8 hours per horn; very tedious, more "art" than "science" :thumbs:
Old Mar 17, 2003 | 12:51 AM
GDaina's Avatar
GDaina
To George:
Roger
:lol: :lol: :lol:
I have to get my horn rebuilt...one of the horns...no sound, nada, zilch
Old Mar 18, 2003 | 08:57 PM
RMS73's Avatar
RMS73
Thanks for the tip about Paragon. Called them and ordered the rivets, no problem. Also ordered to gaskets for templates.
Roger
To Horn Rebuild Kit
