Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
dashpad replacement
Old Jan 16, 2004 | 05:36 PM
corv58's Avatar
corv58
Default dashpad replacement
i am in the middle of a dashpad replacement,i have removed everything.i'm at the point of fitting the new pad.are there any secrets to a safe landing? i know that the gauge cluster and the grab bar assembly need to be cut out,as well as the speaker grille hole. the vette is a 58. thx, jim
Old Jan 18, 2004 | 02:36 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: dashpad replacement (corv58)
I can offer you no help at all. :D ..But Good luck :thumbs:
And we expect to see a picture of it when you get it done.
Old Jan 18, 2004 | 06:31 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
Default Re: dashpad replacement (Desertdawg)
I've helped a few friends do this very project on solid axle cars. I do remember that there is a LOT of trimming of the foam to get the dash pad to actually fit. Sorry I can't be more helpful. Chuck
To dashpad replacement
