Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Sound Deadner
Old Jun 2, 2004 | 09:08 PM
1974ta's Avatar
1974ta
Default Sound Deadner
I have a 70 Roadster.
On top of the transmission tunnel (4 speed) there are three pieces of sound deadner glued down on top of the tunnel. One is in front of the shifter under radio. One is between the shifter an emergency brake, and one is behind the emergency brake.
Also, there is the same padding glued to the top inside firewall area below and behind the padded dash.
Where can I get replacement pieces? They look like unbacked jute padding.
Thank you for any help. I almost have everything I need to correctly reassemble the interior so I can get back on the road!
Old Jun 18, 2004 | 02:09 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Default Re: Sound Deadner (1974ta)
ZIP Products or Ecklers.
Old Jun 18, 2004 | 02:27 PM
1974ta's Avatar
1974ta
Default Re: Sound Deadner (Easy Mike)
Corvette Central had the firewall insulation. I had to by padding by the yard to mke my own insulation for on top of the transmission tunnel.
Thank you for your reply.
Bill
To Sound Deadner
