Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
difference between frame on and frame off
Old Sep 7, 2004 | 09:14 AM
joec's Avatar
joec
Default difference between frame on and frame off
Can someone explain what a "frame on" entails... Just sounds hokey to me....
Thanx,
/joe
Old Sep 7, 2004 | 10:22 AM
docmow's Avatar
docmow
2021 C5 of the Year Finalist - Unmodified
to me it means restoring every where you can do with out moveing
boby such as doing all sides of frame that you can reach and remove
things like spair tire corrier and doing under stuff like that
docmow
Old Sep 7, 2004 | 11:28 AM
KEG64's Avatar
KEG64
The way I understand it is a "frame on" restoration means a restoring the car without removing the body. A "frame off" restoration indicates the body was removed. The terms "body off" or "body on" restorations seem to give a better description of what is actually done.
Old Sep 7, 2004 | 04:59 PM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
64mp's got it right. Don't know how or when the "frame off" nomenclature started but the term "body off" is more correct.
With the body removed from the car, you strip the frame...start with a bare frame, and reassemble/restore everything. Chuck
Old Sep 7, 2004 | 05:14 PM
Nowhere Man's Avatar
Nowhere Man
2015 C2 of Year Finalist
doing a frame on resto is like freshing things up. Ie like a repaint, new interior, engine work, detailed under the hood, and a gone over the chassie. a frame off is redoing everything that the factory did
Old Sep 7, 2004 | 06:15 PM
joec's Avatar
joec
Default ok..
Ok, I sorta figured all of that stuff.. I just didn't know if there was something a little "more" special...
Thanx,
/joe
Old Sep 26, 2004 | 04:49 PM
MosportGreen66's Avatar
MosportGreen66
Put it this way. A frame off resto is when everything with the frame is pulled from the car. A frame on resto is when everything is pulled from the car without the frame coming off. Therefore, a few parts cannot be refurbished.
To difference between frame on and frame off
