Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
Midyear sidepipe question?
Old Dec 6, 2004 | 11:36 AM
RLH
Guest
Posts: n/a
Default Midyear sidepipe question?
Is there a way to tell if a midyear had sidepipes originally, or not? If so, how do you tell?
I have a friend looking at 65 coupe that has sidepipes, and he's curious if they were original or not?
Old Dec 6, 2004 | 12:35 PM
JohnZ's Avatar
JohnZ
There are lots of "clues", but the easiest to spot without putting the car up in the air are:
1. If it's an A.O. Smith body, it didn't have factory sidepipes.
2. If the brackets that stick down from the sill for the bottom attachment of the rocker moldings are there and are bent back out of the way inboard of the pipes or have been cut off, it didn't have factory sidepipes.
3. If the screwed-on triangular outboard splash shields between the bottom of the fender and the frame have the rubber seals stapled to them, it didn't have factory sidepipes.
Old Dec 7, 2004 | 02:54 PM
RLH
Guest
Posts: n/a
John, thanks for that feedback!
Old Dec 14, 2004 | 03:30 AM
Ron D's Avatar
Ron D
4. the rear valance having no holes in it for the tail pipes or having been filled in from someone doing a conversion.
To Midyear sidepipe question?
