Factory Correct Resto Corvette Restoration Tips, Bodywork, Numbers Matching, Period-Correct Modifications or Original Condition
engine identification help
Old Dec 15, 2004 | 01:07 AM
Achille's Avatar
Achille
Default engine identification help
I have two 4 bolt main small blocks I'm trying to identify.
1. 3970010 , V0518TMT , E187
2. 3892657 , 7N169826 , VOIIOMS , L278
Thanks for any help.
Old Dec 31, 2004 | 01:41 PM
clem zahrobsky's Avatar
clem zahrobsky
Cruise-In I Veteran
Cruise-In II Veteran
TMT,74-77 350, 170 HP,2 barrel,truck. MS,67-68 350,295 HP,4 barrel,MT,camaro,nova
Old Jan 8, 2005 | 10:25 PM
56and67's Avatar
56and67
Hi, your #2 block has a information problem. This is a SS-350 Camaro block installed in a 1967 Camaro, serial # 7N169826. The stated casting date is L278 (Dec 27, 1968). This is not possible!! I think if you examine the casting date closer, you will find it is really L276 (Dec 27, 1966) making it correct for 1967 production. By the the way, this was the first 350 CI motor developed by Chevrolet and was only used in 1967 Camaros. It is highly sought after by Camaro restorers.
To engine identification help
