Bloomington "Survivor" questions
In order to pass the "Survivor", the car must make the 40 miles run. With this in mind, the fuel pump just started leaking, and correcting this is not an option. Also discovered that the reason that it heats up is probably because the fan clutch is history.
Knowing these have to be replaced or repaired, this questioin is which way to jump. Supposedly both can be rebuilt, and that would be my preference, but for judging puposes, since they would no longer be original, should I just go with repro parts, or even just off the shelf parts? I have no plans to restore, as I want to keep it as original as posible, but I do want to get it certified.
Your thoughts are greatly appreciated.
Merry Christmas to all.
Frac
GB
just my 2 cents... lucky you for having such a nice original car
With "Survivor", you can have replacement tires, battery, shocks, exhaust, belts, hoses, etc.-the judges are just looking to see if the engine compartment's been repainted-the chassis "repainted", the carpet & door panels changed, etc. The car can be maintained with newer maintenance items and still be "Unrestored". A new fan clutch and fuel pump WOULD NOT keep the car from "passing" the engine portion of the judging so long as the engine compartment IS NOT repainted, the engine REPAINTED and other pieces in the engine compartment "replated or restored".
Thanks for the info. This makes me feel a lot better about what I am having to do. With this in mind, I'll put the new parts on and hang on to the old ones, in the event that they may be needed down the road if some one other than me wants to do a restoration on it. I may go ahead and have them rebuilt to have handy.
I'm looking forward to the getting the application completed as soon after the first of the year as Bloomington posts it.
Thanks again, and Merry Christmas.
Frac
GB
