Is it located in the floor board, because all I see is pink and green connectors.
I am guessing you are at the BCM. You aren't going to find that circuit there. The PCM is in the RF wheel well below the battery. Another access point is at the underhood fuse box. (In the bottom of the fuse box) the large black connector terminal D4 white wire or one of the two grey connectors terminal A3 white wire.
One other hope of finding the circuit inside the car but not at the gauge cluster, is to find where the main wiring harness from the underhood fuse box comes through the firewall on the RH side of the dash and try to figure out the correct white tach wire.
well i will most likely see you guys there. i have made all of them so far i think.. and dont worry about being slow.. i cant break the 12.8 for the life of me.. lol
weather looks great but I would have hoped for cooler air!!
Vic
Cooler would definately be better, lets hope the wind keeps itself in check, 20+ mph winds from the Southwest.... lets hope its more from the west.... warm temps and headwind are gonna hurt anyone looking to best thier ET's
Track pretty much runs straight south so a SSW wind will be at our faces and right side on the way down, looks like the earlier in the day the better our chances are of avoiding the big winds.
I would like a baro reading of 31+
Negative DA
Low 60's for temps
Clear sunny skies
A nice 10-20 mph wind from the north
and a track prepped so good you could launch a 1000rwhp car on bald runflats
Negative DA
Low 60's for temps
Clear sunny skies
Hey Larry if you did know it Mike that had the orange formula. See ya Saturday.
Hopfully all my work paids off. O by the way my 2 buddies are coming with one has a Mustang and the other has a Trans Am. You guys are welcome to see if you can handle either. No ford guy at all but I have a lot of resecpt for this one.
Mike....sorry I missed this post.
I am not going to claim I will show good ET tomorrow, but MPH will be shining. I hope your boys have some modded rides if the plan to hang
LAYNLOW... are you going to show ? don't be afraid to bring the stocker out for a couple runs
