Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Powder Coating
Old Nov 13, 2011 | 08:12 AM
SinisterC6's Avatar
SinisterC6
Speedy
2024 C8 of the Year Finalist - Modified
Default Powder Coating
Does anyone know a good powder coater? I would like my comp grey rims stripped and coated flat black
Old Nov 13, 2011 | 09:35 AM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Just Googled these???
http://protekpowdercoating.com/
http://www.rimrepaircenter.com/
Old Nov 13, 2011 | 06:38 PM
SupermanZ's Avatar
SupermanZ
Cruise-In VIII Veteran
Cruise-In IX Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11
I've seen some work performed by these guys for Glenn (Batman) and it is good. They are located in Oak lawn.
http://www.lo-ko.com/
Old Nov 14, 2011 | 03:10 PM
Robls6's Avatar
Robls6
Can't beat Pro Tek. Jay is a friend of mine and has done a lot for both me and my brother over the years. Last time I was there he had a new Lambo wheel in there as a showpiece. It looked amazing.
Old Nov 14, 2011 | 03:50 PM
1powdercoater's Avatar
1powdercoater
Default powdercoating
I happen to know a very good powder coater in the Huntley, IL area
Old Nov 14, 2011 | 10:23 PM
Thanks for posting up the recommendations - may want to use one of these guys some day.
Old Nov 14, 2011 | 10:39 PM
1powdercoater
Default powder coating
Not sure if I can promote myself here. If not I guess I'll be told.
Paradigm Coatings
847-961-6466
Huntley, IL
Powder Coating & Media Blasting Services
Old Nov 20, 2011 | 08:41 AM
Corvetteherb's Avatar
Corvetteherb
6th Gear
In case someone would like to do your own powdercoating at home, I have been powder coating at home for the last 5 years with great success. I've done hundreds of parts from nuts and bolts, brackets, intakes, wheels, valve covers to interior trim parts and much more. The results give a very professional look to any restoration project. I wrote an article to help take the mystery out of the process for the do-it-yourselfer. If you'd like to get started powder coating, just send me a PM with your email address and I'll get it right back to you.
Old Nov 20, 2011 | 08:02 PM
FreddyG's Avatar
FreddyG
You must have a pretty big oven to fit a rim into, especially one of those GS or Z06 rears, especially at home.
Old Nov 21, 2011 | 07:03 AM
Corvetteherb
6th Gear
Default Yep, the oven is big!
FreddyG, you're right some of those wheels are enormous. My powder coat oven is only big enough for those mid-80's 17 incher wheels. I'd like something bigger but it's also big enough for intakes, heads, I even did a drive shaft, countless brackets, timing covers and on and on. Overall I'm pretty happy with what I can put through my oven, until I can find one that's bigger!
To Powder Coating
