Great Lakes Illinois | Indiana | Iowa | Michigan | Missouri | Minnesota | Ohio | Wisconsin
Emissions testing.
Old Oct 24, 2020 | 11:49 PM
iLLest's Avatar
iLLest
4th Gear
Default Emissions testing.
So I bought a C5 with a check engine light due to the car not having any converters on it, so my question is how do you guys pass the test without having to put them back on and re working the exhaust system again. I believe all they do is just run the test through the OBD port. Im located in Chicago.
Old Oct 25, 2020 | 01:43 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Best wishes...
"[size=16px]If one or more trouble codes appears on your vehicles test, erasing the the codes won’t fix the issue, you need to diagnose the troubles code(s) and repair the cause of the trouble codes appear. Make sure there no new trouble codes appears again, you should OBD monitors self-test run completely (you can verify it using a scan tool). This the only way to make your vehicles pass on the OBD II plug-in emissions test."
https://www.aa1car.com/library/us50326.htm[/size]
Old Oct 25, 2020 | 01:57 PM
sunflower 1972's Avatar
sunflower 1972
You need to find someone with an OBDII tuning software program. The rear O2 sensors can be "turned off" so the missing O2's won't turn on the SES light.https://www.corvetteforum.com/forums...2-sensors.html
To Emissions testing.
