Help Forum How To | General Corvetteforum Questions | Feedback
Signatures
Old Sep 26, 2005 | 04:06 PM
cmb13's Avatar
cmb13
Default Signatures
I recently went to Edit Options to switch on "Show Signatures". I notice that, even for those who do have signatures, some signatures are displayed in the threads and others are not.
Why is it that I see some peoples signatures in their posts, while I do not see other peoples signatures in their posts. For instance, why is mine not displayed?
Any thoughts?
Old Sep 26, 2005 | 05:22 PM
RichF's Avatar
RichF
St. Jude Donor '03, '04 & '05
When you are starting or replying to a thread, under the white reply box , scroll to "Miscellaneous Options" and check "show your signature"
Old Sep 26, 2005 | 11:08 PM
cmb13's Avatar
cmb13
Oh. I think I'll try it now! Thanks.
-cb
Old Sep 26, 2005 | 11:10 PM
cmb13's Avatar
cmb13
It worked! Interesting, so you must actually hit the option every time you post, if you so desire? Doesn't seem worth it if it isn't automatic; sort of a vanity thing.
Old Sep 27, 2005 | 08:15 PM
RichF's Avatar
RichF
Yes... originally Troy had "show signature" set as the default, but because so many people requested that the sigs be turned off as the default, he changed it.
Old Sep 29, 2005 | 10:43 PM
Mpwr's Avatar
Mpwr
just seeing if my sig works
Old Oct 25, 2005 | 06:14 PM
Jchimknee's Avatar
Jchimknee
From: Mr JUNE: Reconnaissance Marine, USMC 2007 Calendar
St. Jude Donor '06
First post, trying to see how it looks and if I've done this right.
Ok, done something wrong. Be back shortly
Old Oct 25, 2005 | 06:19 PM
Jchimknee's Avatar
Jchimknee
St. Jude Donor '06
Hope this works cause I'm really not good at this post/reply stuff.
Still not working and I'm not going to get my husband. Somehow this is the reverse of when guys don't ask for directions--now I understand!
Ok got the quote under the picture to work. Now I just have to hope no one finds out just how new at this I am.
Old Oct 25, 2005 | 07:07 PM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
When posting a reply...see the section below "Miscellaneous Options"? (Click on the sample pic below)
Check "Show your signature" and then Submit Reply
Old Oct 25, 2005 | 10:28 PM
Jchimknee's Avatar
Jchimknee
St. Jude Donor '06
Thank you, thank you
Old Oct 30, 2005 | 08:47 AM
SHRKATTK's Avatar
SHRKATTK
Trying again. Still no ##*+# sig
Old Oct 30, 2005 | 03:57 PM
MrWhan's Avatar
MrWhan
Your sig shows for me, so try this:
Go to User CP
Click on Edit Options
Look for the Thread Display Options Section
Make sure Show Image, Avatars, and Signatures are checked
To Signatures
