Help Forum How To | General Corvetteforum Questions | Feedback
Tech Section - Tech Articles - Where Is It?
Old Mar 11, 2008 | 03:46 PM
Tim_Ko's Avatar
Tim_Ko
Default Tech Section - Tech Articles - Where Is It?
Hello,
I was reading about govenors on a 700R4 and the author referred to the TECH SECTION. I looked but could not find it. Where can it be found?
Thanks,
Tim
According to http://www.transonline.com/electroPu...fm?pageID=2243 the standard weight for a V8 is the heavy one (with added weight). The lighter is for a 4cyl...
I don't get this, weights have to do with rear ratio/ tire size, not engine type??
Btw: I just did some tests with new springs and it now goes into 4th at 35mph and shift at WOT without valves floating. Best result so far. This is with the light weights.
I have it all documented in the 700r4 article, tech section.
[Modified by Ingar, Norway, 12:22 AM 4/28/2002]
