Help Forum How To | General Corvetteforum Questions | Feedback
How do I make avatars?
Old Apr 1, 2008 | 01:47 PM
one18Vette's Avatar
one18Vette
From: If You gave Your life to love them, so will I
St. Jude Donor '07-'08
Umm... photobucket can resize it to avatar size.
Old Apr 1, 2008 | 01:49 PM
...Mark...'s Avatar
...Mark...
pssttttt.... You don't have to resize pics on this forum.. Just go to your CP and upload the pic and it automatically does it for you..
Old Apr 1, 2008 | 01:52 PM
_Will_'s Avatar
_Will_
From: Somewhere between mild insanity and complete psychosis
Originally Posted by lilredcorvette
Will, I've not been able to get it to resize for me... is there a secret handshake I don't know about?
Go to your control panel, choose custom avatar, browse for any picture file on your pc you want, and viola - it will be your new avatar, no matter what the size. If it was too big, the forum automatically shrinks it down to size.
Old Apr 1, 2008 | 03:09 PM
lilredcorvette's Avatar
lilredcorvette
Cruise-In III Veteran
I got this msg this time..... This is not a valid image file.
Attempt #2= Invalid URL
Attempt #3= Remote file is too large
Old Apr 1, 2008 | 08:27 PM
Just J's Avatar
Just J
Cruise-In Photographer
CI 1, 2, 7, 8, 9, 10 Veteran
St. Jude Donor '06 thru '26
I downloaded Irfranview and resized the pics but they're still waaaaaaaay too big. What format should I be saving them in? I think they're bmp's right now. On photobucket they show up as jpgs...
Irfanview Instructions:
  1. Open the file you want to make into an avatar.
  2. File, Save As to a new name to avoid damaging the original. Use JPG format, quality 90.
  3. Image, Resize/Resample to 150 pixels on the long side. Preserve Aspect Ratio should be checked, and I use the Lanczos resample filter.
  4. File, Save, but do not exit.
  5. Check the file size on disk to see if it's under the 29.3kb limit. If it is, you're done and can exit Irfanview and then upload the photo as an avatar. Otherwise, do File, Save and lower the quality by 10. Repeat this step until the file is small enough to use as an avatar.
Old Apr 1, 2008 | 08:37 PM
Sven's Avatar
Sven
St. Jude Donor '08-'09
Originally Posted by FasterTraffic
You can do it in MS Paint.
You can do it in Photobucket ... resize, avatar.
Old Apr 1, 2008 | 10:20 PM
lilredcorvette
Originally Posted by Just J
[*]Check the file size on disk to see if it's under the 29.3kb limit. If it is, you're done and can exit Irfanview and then upload the photo as an avatar. Otherwise, do File, Save and lower the quality by 10. Repeat this step until the file is small enough to use as an avatar.[/LIST]
That's the one!! Problem solved!!
I'll let you know how it turns out. THANK YOU!!!!
-April
Old Apr 1, 2008 | 11:50 PM
BOTYNV1's Avatar
BOTYNV1
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19
And stop using the beautiful baby to set your avatar
J/K
Old Apr 2, 2008 | 06:26 AM
MrWhan's Avatar
MrWhan
CI 3-4-5-6-7-8 Veteran
St. Jude '03 thru '26
-April
Irfanview is what I use. I can also crop with it to make the pic more of what I want by clicking in the pic and dragging my mouse, then Edit/Crop.
Old Apr 2, 2008 | 08:42 AM
Just J's Avatar
Just J
-April
