Help Forum How To | General Corvetteforum Questions | Feedback
Creating an avatar
Old Jan 3, 2011 | 09:48 PM
brooklync5's Avatar
brooklync5
Default Creating an avatar
Hey guys maybe some of you can help me create an avatar? Thanks
Old Jan 3, 2011 | 09:55 PM
Vette_DD's Avatar
Vette_DD
USERCP in the red menu line, then "Edit Avatar."
But you'll probably get more help in the HELP forum if that's not enough information.
http://forums.corvetteforum.com/help-forum-31/
Old Jan 3, 2011 | 10:18 PM
J T's Avatar
J T
IB Staff
Editing the Avatar is done via the UserCP under Edit Avatar as Jim stated above.
If you need help with actually editing a photo you have to fit the constraints for an Avatar, there are two programs that I personally recommend when needing to edit images. Both programs are free:
The Gimp: http://www.gimp.org/
This program can be quite complex, thus, it can take time to learn how to use. However, it's a powerful program when needing to edit photos.
IrfanView: http://www.irfanview.com/
This program is lightweight and pretty easy to use, although it's not as powerful as The Gimp. This program will do your basic editing (setting dimensions, cropping, etc.).
Using IrfanView as an example, which after you download and install it, click on File and Open to locate the image on your computer that you wish to edit. To simply scale the photo down to fit a set pixel dimension, you can click on Image and Resize/Resample. Under the Set New Size, enter the dimension you want the image to be. Make sure Preserve Aspect Ratio is enabled so that the image isn't distorted. With the Preserve Aspect Ratio set, you will only be able to enter a Width or a Height and the system will calculate and fill in the other value to preserve the aspect ratio.
Hope that helps get you started.
Old Jan 4, 2011 | 12:43 AM
brooklync5's Avatar
brooklync5
that did the trick. thanks for your help been wanting to do that for a while
Old Jan 4, 2011 | 12:56 AM
Vette_DD's Avatar
Vette_DD
You're welcome.
Looks good.
I figured JT would be of invaluable help if you had any trouble at all.
Old Jan 4, 2011 | 02:42 AM
brooklync5's Avatar
brooklync5
thank you as well sir!!
To Creating an avatar
