Aaaaaaaaaaaargh!!!!!
Microsoft actually has a KB for this issue of having some (but not all) websites display that error while using Internet Explorer 8 or Internet Explorer 9 on Windows 7, which what you describe as having.
Please see the following Microsoft KB article about this issue and see if it can be used to help:
http://support.microsoft.com/kb/967897
If you don't want to mess with the above, my next suggestion would be to try Firefox or Chrome.
As bad as Onstar from GM imho ........... Google tracks everything and adds it to their database.
Chrome is a pretty secure, fast and stable, web browser but it does come with personal concerns. However, you don't exactly need Chrome to be tracked as you'll find a lot of other examples of data collection in the real world.
CF has embedded scripts from external sites for functionality/content. In those cases, CF is instructing your computer/browser to make a connection to those sites to load external scripts for functionality/content. CF is not actually making those connections and delivering the content directly to you - instead it's directing your computer/browser to those sites and thus the connection is between you and those sites.
To better explain this, it's like someone embedding an image from an external site here on CF. The following image you see, which I embedded, is being loaded between you and Google. It is not being hosted by CF and CF is not loading the following image for you via any connection between CF and Google - instead CF is simply telling your computer/browser to make a connection to Google to load the following image. This is the same principal with the external scripts that are being called/embedded as described above.
CF is not making the connection to those sites. It is referring your computer/browser to those sites for additional content/functionality. The connection is between you and those sites.
However to the end user, it just makes CF load really slow thus looking like CF has the problem, which it does. The problem is both the 3rd party connections *and* it's a CF issue.
I always disable 3rd party scripts, ads and cookies and block superfluous HTTP connections by default in any browser I use. Still, CF is probably the slowest site I visit and always has been. I attribute this to the way the CF webmaster has chosen to use the vBulletin package on the server. Nesting data tables is usually the culprit. Other vBulletin sites I visit do not have these speed issues, at least not to the degree that CF does.
I also agree. It still appears to me that CF is the slowest loading, yet most favorite site, I visit. I was having some laptop issues a couple of weeks back, which curtailed some of my "surfing" until I got a new laptop, and I wasn't over at the LS1 Tech site for a while. I've gone over there several times in the last 2-3 days, and I see that their loading times are a lot slower now, too....
Those who are seeing CF take 30+ seconds to load or having to refresh the page 6-12 times does not appear a typical or widespread experience. In those cases it appears to be an IE9 related issue, which I had linked to a Microsoft KB Article that discusses, and provides some suggestions, for some sites not loading correctly while others do load normally.
As far as LS1Tech, I've also noted a performance degrade over the past few days in addition to an elevated server load. We'll have that looked into.
I assumed for a while it had to do with my computer being old, but I got a new one recently and now it seems slower than ever, using IE 9. Out of necessity, I've switched to FireFox and the difference, at least for me, has been significant.
I'll add this issue to the list of things I want to discuss with the people who are my liaisons at IB and vBulletin.
Meanwhile, I have taken your suggestion and listened to the jazz. Good stuff!
More on that via PM.
More on that via PM.Nonetheless, thanks for your attention!!
Savewave and I had discussed some of this, and some with slow loading appear to be IE9 users as a common factor. I previously linked to a Microsoft KB article about IE9 and it having some issues with certain sites but not all sites. Did you give Firefox a try to see if that made any difference?
As far your experience on LS1Tech, while part of the issue may be related to what you're seeing on CF, I also noted a server load concern that I've raised and awaiting review.
I ran several tests on CF using both IE8 and Firefox. In those tests, the site continuously loaded normally (within seconds) while using both IE8 and Firefox. Personally, I've not experienced CF loading abnormally slow when using IE8 or Firefox (with no ad or script blocking). I think the issue some are having are IE9 related, and/or some other local issue. The rest could just be, due to owning a Corvette, think everything else is just slow
I ran several tests on CF using both IE8 and Firefox. In those tests, the site continuously loaded normally (within seconds) while using both IE8 and Firefox. Personally, I've not experienced CF loading abnormally slow when using IE8 or Firefox (with no ad or script blocking). I think the issue some are having are IE9 related, and/or some other local issue. ...
It gives me load times of up to 40 seconds on some tasks. The same tasks with FireFox are taking a second or less.
There must be some incompatibility issues with the Forum and IE9. I'll discuss it with IB, but until the issue can be resolved, just switch to FireFox.
To Help section from main directory = 392ms
To this thread = 404ms
Making this post = 239ms
Last edited by savewave; Aug 23, 2011 at 09:48 AM. Reason: To add the 239ms time on this post
To Help section from main directory = 3 seconds
To this thread = 23 seconds
Making this post = 6 seconds
Last edited by savewave; Aug 23, 2011 at 09:51 AM. Reason: To add the 6 seconds on this post
However, note that even if you do make a mistake and give it permission to be your default browser, you can easily revert that change later.
