Can you describe the issue? Nothing on CF's end, regarding picture posting, has changed. You simply have the URL of the image inside a set of IMG tags if you want them embedded inside a post.
I looked for previous examples of you attempting to post pictures, so that I could see what the issue might be, but I could not locate any.
If I use the "Insert Image" icon above and copy, paste the photobucket http://....... all I get is a picture with a red x on it. I will try to post and image in this post.
Click on the IMG code (see attachment), which will copy the IMG code to your clipboard. Then, simply paste that inside a message here on CorvetteForum.
