Help Forum How To | General Corvetteforum Questions | Feedback
YouTube not Embedding
Old Jan 29, 2015 | 06:07 PM
dharmadan's Avatar
dharmadan
Default YouTube not Embedding
Hi,
When I use the YouTube tags [YT ] [ /YT] by clicking above the message body, the video doesn't embed, whether posted or previewed.
One night, I kept editing it, and ended up using the Insert Link instead, and that worked then, but haven't been able to repeat success.
Thank you in advance. Dan
Old Jan 29, 2015 | 06:48 PM
J T's Avatar
J T
IB Staff
We will investigate.
That said, the YT tags used in the toolbar are the old legacy way of embedded YouTubes and required posting the YouTube video ID between the set of YT tags and nothing more.
Today, you simply need to paste the entire URL without any tags inside a post and the software will automatically convert it to embed.
For example:
Code:
Simply pasting this:
https://www.youtube.com/watch?v=-eqtxX3G-7A
Will result in this:
Originally Posted by dharmadan
Hi,
Old Jan 29, 2015 | 06:55 PM
dharmadan's Avatar
dharmadan
Cool! Thanks J T !
Old Jan 29, 2015 | 07:08 PM
J T's Avatar
J T
IB Staff
I did some checking and everything looks correct and searching for posts that use the legacy YT tags appears to be working correctly.
Are you using any browser extensions? Like Flashblock? Are you posting the correct portion of the URL inside a set of YT tags? Remember, you only post the video ID, which is the string after the v= in the URL if using the YT tags.
Like I said, the new method does not use the YT tags and just requires a complete URL of the YT being posted.
Hi,
Old Jan 29, 2015 | 07:25 PM
dharmadan's Avatar
dharmadan
That's it -- I was using the entire URL. (It's the loose screw between the seat and keyboard -- lol!)
Thank you for your help. <3
Old Feb 25, 2015 | 02:57 PM
Sir Nuke's Avatar
Sir Nuke
JT, I am fairly new in the big scheme if things but been on forums for a LONG time. I too had the same problem as the OP the first time and I was successful for the simple reason that I too just tried using the URL link and it worked. BUT I had looked at the "HOW-TO embed a YouTube video" and as you can see its totally out dated, seeing as how it was written in 2009. It would be very helpful if someone would update the Sticky to something useful for the newbee's ...... or us old folks! lol
Old Feb 25, 2015 | 03:53 PM
J T's Avatar
J T
IB Staff
I will update the Guide. However, the old method outlined still works. The problem that sometimes occurs, and the OP confirmed this was their mistake, is that when you use the YT tags you do not use the entire URL. You simply use the YouTube Video ID surrounded by the YT tags.
Old Feb 25, 2015 | 04:23 PM
Sir Nuke's Avatar
Sir Nuke
OH Ok.....but if nothing else.....all you see are broken links for all of the pictures in the OP of the HOW-TO
To YouTube not Embedding
