Help Forum How To | General Corvetteforum Questions | Feedback
SEARCH feature....
Old May 31, 2015 | 07:57 AM
Sluefoot's Avatar
Sluefoot
Default SEARCH feature....
I can NEVER get any search to produce any results...
I click on the "search", and type in "repair clock", and I get
NOTHING.....I've tried many times....what am I NOT doing right??
(I want to see if there's any help/videos on my '79's clock)
Thx!
Old May 31, 2015 | 08:43 AM
'75's Avatar
'75
Have you tried using the advanced search in the search drop down? It works pretty well when I try it. Advanced search
Old May 31, 2015 | 08:47 AM
wendellp601's Avatar
wendellp601
Here's what I get when I search for "repair clock" using the quotation marks.
However, I usually use the Advanced option on the right just under the search bar. This will allow for "Search Entire Posts" by default, but you can select "Search Titles Only".
Also - down at the bottom in the Search in Forum(s), the default is Search All Open Forums. I un-check this box and scroll down to choose " C3 Corvettes, 1968 - 1982"
Old May 31, 2015 | 08:52 AM
BKarol's Avatar
BKarol
Most times I give up with the search and use google. "repair a 79 corvette clock". Came up with a link to CF and this: http://www.superchevy.com/how-to/24699/
Old May 31, 2015 | 11:51 AM
ddawson's Avatar
ddawson
Doesn't answer the question but I sent mine to http://www.clockwks.com/The_Clock_Worx.html.
Came back fast and not very expense.
Old May 31, 2015 | 01:16 PM
65GGvert's Avatar
65GGvert
The best way to get GOOD results is go to Google, type in your search term and put "corvette forum" after it. You'll get only things that apply to your question and not all the extra garbage
Old May 31, 2015 | 02:05 PM
havesometo's Avatar
havesometo
Thx!
At the top of this page you'll see a little house click on it and when the next page comes up you'll see a search bar type in whatever you need to find there and you will find what you're looking for. Hope this helps.
https://www.corvetteforum.com/forums...repair&type=wp
To SEARCH feature....
