This is stupid I know...but my signature won't show
I'm very familiar with these Forums. I've successfully setup signatures on multiple forums that use this setup but I still can't get it to show here. I went into User CP and set it up. Saved it. I then select "Show signature" when I posted several times but it never shows up.
With my luck, it will probably show up the next time I post. But is there any other setting that I am missing here? Thanks..
https://www.corvetteforum.com/forums...elp-guide.html
We ask that members take some time to read the Stickies and Announcements as they contain important and frequently asked information. The above referenced link is for the Help Guide sticky, which covers this topic.
You must manually select Show Signature each time you post. This is because members generally don't want to see the same signature from the same member posting multiple times in one given thread. It is redundant and consumes screen space.
I know both of those things. I selected that box even to start this thread. And I selected it on a few other posts yesterday and it never shows no matter the circumstance. It’s okay I guess I can live without it.
You have Display Signatures turned off in your UserCP.
If you read the Help Guide as I linked, that is also noted:
"Tip: Make sure you have Display Signatures enabled in your account or you will not see any signatures at all. To check this option:"
