75 corvette coupe door stuck closed
I have looked up the old posts(threads) on how to open a stuck door on C3 Corvettes, but have been unsuccessful in getting the driver side door to open, The door is manual with no power locks or windows. The door is closed shut with no door panel on , I tried pushing down on the lever that puts pressure on the door latch striker,just behind the rod that comes up externally from the interior lock. I have played around with the passenger door that is off the car, and when I push down on the lever I hear a click and the striker clip disengages. Pleas eany ideas of how to get the driver's door to open would be appreciated.
The door itself may be stuck shut. Try jacking car up a little right at the rear door gap. Flex a bit and change where latch is on striker.
MCallan (09-19-2018)
now, don't close it! pull the latch out. see how the door opens and closes with no latch. without being jacked up. get the latch working on the bench and then in the door latching it on a screwdriver or something. now you can close the door.
Thank You, Thank You; I needed the picture with the linkage in it to determine the push point. In addition, I had my son get in the car and push had on the door while I pushed down on the bracket. It opened and now works better then it every has. I have to pull off the panel to try to find out what it was that was blocking it from opening.
Thanks Again to all that assisted!
