Help Forum How To | General Corvetteforum Questions | Feedback
Codes 1271 & 1272
Old Aug 18, 2019 | 04:17 PM
scopel56's Avatar
scopel56
3rd Gear
Default Codes 1271 & 1272
I sent my EBCM (ABS) in for repaired. Repaired and codes cleared. Reinstalled Module and codes 1271 & 1272 appear w/ABS and Traction Control Icons on dash. The 1271 & 1272 reference master cylinder and LF wheel pump.The associated parts referenced by the codes 1271 & 1272 check out and are working well. Can't clear codes and icons on dash via car. Any ideas have to clear these false codes? C5 2000 coupe 5.7
Old Aug 18, 2019 | 05:06 PM
J T's Avatar
J T
IB Staff
This Help section is for Help with the CorvetteForum website (account issues, etc.,) and is not the place to post technical questions about Corvettes. Instead, please find the correct section, based on the generation of the Corvette.
Go back to the main forum page:
https://www.corvetteforum.com/forums/
Now start to slowly scroll down until you see the generation of your Corvette. 2000 Corvette? That's covered under the C5 Corvettes, 1997 - 2004 section:
https://www.corvetteforum.com/forums...s-1997-2004-2/
Got a technical question about the 2002? Use the C5 Technical section:
https://www.corvetteforum.com/forums/c5-tech-1/
General question? There's a C5 General Section:
https://www.corvetteforum.com/forums/c5-general-103/
Thank-you
Old Aug 18, 2019 | 05:19 PM
scopel56's Avatar
scopel56
3rd Gear
Thank you.
The site can be a little confusing when you're a new subscriber - there's really no navigating instruction per se....
Old Aug 18, 2019 | 05:52 PM
J T's Avatar
J T
IB Staff
Nearly every website is different, so we encourage new members to take some time to familiarize themselves with the site in terms of layout and usage as well as take some time to read all the Announcements and Stickies as they contain important and frequently asked information.
Each generation of Corvette (except for the C1 and C2 - those are shared sections) have their own sections. Each of those sections contains all relevant areas of discussion from technical questions to For Sale and Wanted Ads. Outside of that, there are other miscellaneous sections for other areas of discussion (such as Regional meets and discussions, non-Corvette car questions, etc.,).
Thanks and good luck!
Originally Posted by scopel56
Thank you.
To Codes 1271 & 1272
