Help Forum How To | General Corvetteforum Questions | Feedback
Adding animated avatar
Old Nov 27, 2019 | 05:49 PM
Matthewstorm's Avatar
Matthewstorm
Default Adding animated avatar
How do I add an animated avatar? Like, HOW do I do it. Thanks.
Old Nov 27, 2019 | 09:07 PM
J T's Avatar
J T
IB Staff
Instructions for changing Avatar are in the Help Guide, which is a sticky in this section:
https://www.corvetteforum.com/forums...elp-guide.html
We encourage members take the time to read all Stickies as they contain important and frequently asked information.
Using an animated avatar is no different, upload wise, than the standard avatar as described above.
However, if you're asking how to create one, that goes a bit beyond the scope of the forums and using Google with the appropriate software will likely be necessary as sites like CorvetteForum do not create animated avatars.
Old Nov 28, 2019 | 07:20 AM
Grumpy's Avatar
Grumpy
MONARTOR
From: What I know, is dwarfed by what I pretend to know
Cruise-In 5-6-7-8 Veteran
AvatarsImages used for avatars should be in good taste. No "babe" pic's, no controversial, suggestive or offensive images or messages are permitted.
Moderators will determine the appropriateness of any avatar, and will remove any avatar deemed in violation.
Images should be limited to no more than 150 pixels wide and should not be vertical images.
Moderators, regional events coordinators, and gold supporting members, are allowed to use animated gifs for their avatars. All others should use .jpg format images.
To Adding animated avatar
