Hello all. Bought a new '07 last year after a long absence from Corvettes. Unfortunately parked it in garage last December without a trickle charger and now the battery is dead! Anyone know where the manual key slot is? My dealer says its at the rear but I must be blind (as well as dumb!) 'cause I can't find it.
Thanx
The key slot is in the rear look above the lin.plate I think it is on the right side,it's easier to see if you lay down and look up after you find it then it will be easy to use without bending over I hope this helps.
Tony
Welcome aboard and sorry to hear about your battery. with the above the key slot is located just above the rear license plate next to your button to open the rear hatch.
Welcome to the Forum!!!!!!! Hope to see you participating in C6 General. And, just a heads up, that is where you should post your questions in the future.
Here is the Help Tutorial on posting pictures if you need it:
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Thanx
