Studdering new member.
Nov 6, 2009 | 12:08 AM
Hi. I'm a new member from beautiful Detroit, Michigan. I purchased a 1986 C4 L98, automatic trans, 85,000 miles about two weeks ago and this site has been invaluable. The only real issue I have with the car is studdering. It seems to happen after it reaches the shift points. If I put the pedal to the floor it won't studder or shake at all. It has no problem shifting. The car starts and idles fine. It drives great except for the studder upon acceleration. Any advice? Thanks, Tom
Nov 6, 2009 | 01:35 AM
From: Ideals are peaceful...History is violent...St.Charles, MO.
C5 of Year Winner (appearance mods) 2019
St. Jude Donor '08-'09-'12 thru'22
Welcome to the Forum!!!
Nov 6, 2009 | 02:32 AM
Welcome to the forum,try asking your questions in the C4 section below, I'm sure you will get your most informed replies there..
Nov 6, 2009 | 05:14 AM
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck with the problem! I agree - look at the C4 section.
Nov 6, 2009 | 05:47 AM
Welcome
Chuck
Nov 6, 2009 | 08:03 AM
St. Jude Donor '11-'12-'13-'14-'15-'16-‘17-‘18
Welcome to the forum! If you go to the C4 forums under tech someone will be able to pin the problem down for you. There are several posts that may be related to your issue. Good luck!
Nov 6, 2009 | 09:11 AM
Welcome to the forum.
Nov 6, 2009 | 10:27 AM
Welcome aboard!
Nov 6, 2009 | 10:37 AM
Welcome to the Forum!!!!!!!!!!
Enjoy.
Nov 6, 2009 | 12:23 PM
St. Jude Donor '13, '20-'21
Nov 6, 2009 | 01:40 PM
Welcome to the Corvette Forum!
Nov 6, 2009 | 01:48 PM
Nov 6, 2009 | 03:09 PM
Nov 6, 2009 | 05:25 PM
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard.
Nov 6, 2009 | 11:01 PM
Welcome to the Forum and congratulations on your 86 Those guys in C4 will help you get that worked out.
Nov 6, 2009 | 11:24 PM
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Welcome aboard Corvette brother from Port Huron.
Nov 7, 2009 | 07:08 AM
Welcome to the Forum.
Nov 7, 2009 | 08:27 AM
Welcome aboard. Enjoy !!!!
Nov 9, 2009 | 12:25 AM
Congratulations on your new Corvette & Welcome to the Forum! As you've already seen lots of great information & knowledgeable Vette owners here!
Nov 9, 2009 | 10:50 AM
St. Jude Donor '08-'09-'10
National Champs Gators 4 St. Jude '09
