Weekender
Feb 15, 2010 | 03:11 PM
4th Gear
Weekender
I am unable to turn the key above the back plate to release the trunk to access the driver door to open the hood, to boost my 2007 corvette.
Is there any helpful hints I am over looking?
The Weekender
Feb 15, 2010 | 03:17 PM
St. Jude Donor '13, '20-'21
Welcome to the forum! You do not say where you are located so it could be different problems. The time my battery went out in my '06 the key turned fine, without any trouble. Have you tried graphite or a de-icer, depending on your conditions? Good luck
Feb 15, 2010 | 03:21 PM
4th Gear
Weekender
I am in Canada, my 2007 Black Corvette is in the garage for the winter,
I wanted to start it up but I am unable to turn the key.
Feb 15, 2010 | 03:22 PM
4th Gear
Quote:
Originally Posted by
norm laurin
Feb 15, 2010 | 03:24 PM
norm laurin
If the lock has frozen it will not turn. They sell a special spray that a friend used, that allegedly de-ices the lock and will let it turn.
Feb 15, 2010 | 03:30 PM
4th Gear
Weekender
Thanks neighbour
I bought my corvette May 2009 and it was the best thing I ever did.
Thanks for your help, the forum has helped answer some questions in the past.
Feb 15, 2010 | 06:37 PM
Hello and welcome to the Corvette Forum.
Feb 15, 2010 | 07:39 PM
St. Jude Donor '08-'09
Welcome to the forum..
Feb 15, 2010 | 07:52 PM
Welcome to the Forum!!!!!!!!!
Those locks can be very difficult to turn.....sometimes just because that's the way they are, sometimes due to dirt or being frozen. Push down on the hatch/trunk above the lock while trying to work the key repeatedly. Good luck.
Feb 15, 2010 | 07:53 PM
Feb 15, 2010 | 08:05 PM
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Welcome to the Corvette Forum!
Feb 15, 2010 | 09:08 PM
Feb 16, 2010 | 12:20 AM
Welcome to the Corvette Forum - As you've already seen, lots of great information & knowledgeable Vette owners here!
Feb 16, 2010 | 06:36 AM
Cruise-In VI, VII & XII Veteran
St Jude Donor '07-'08-'09
Welcome aboard.
Feb 16, 2010 | 07:57 AM
Welcome
Feb 16, 2010 | 08:50 AM
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck with the problem!
Feb 16, 2010 | 10:47 AM
Welcome aboard!
Feb 16, 2010 | 05:40 PM
Welcome
Chuck
Feb 18, 2010 | 08:14 PM
Welcome to the Forum and good luck with that situation
Feb 19, 2010 | 12:24 PM
Account disabled by request Dec 2015
