2001 10-pcm code engine light
Old Mar 20, 2012 | 03:31 PM
VTDREAM's Avatar
VTDREAM
Cruising
Default 2001 10-pcm code engine light
Bought recently used 2001 and had a few issues. ABS and Traction Handling lights came on. First tried removing battery cable, didnt work. Replaced ABS control module, problem fixed. Now Engine light is on and DIC says, 10-PCM 2 codes. Pressed reset, lasts a couple of days then comes back on. Any thoughts that cld fix. Otherwise love the car.
Old Mar 20, 2012 | 04:02 PM
MacC608Vette's Avatar
MacC608Vette
WELCOME TO THE FORUM - You can post your question in the C5 section and get your answers quicker. This section is mainly for introductions of who your are and what you purchased. Good luck on finding your answers.
Old Mar 20, 2012 | 04:22 PM
VTDREAM's Avatar
VTDREAM
Cruising
Tks!
Old Mar 20, 2012 | 05:45 PM
VETJAZZ's Avatar
VETJAZZ
Welcome to the forum. Good luck with your issue - common problem.
Old Mar 20, 2012 | 06:06 PM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome aboard!
Old Mar 20, 2012 | 07:13 PM
guappy's Avatar
guappy
Old Mar 20, 2012 | 09:02 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Mar 21, 2012 | 06:45 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome!
Old Mar 21, 2012 | 08:28 AM
gilhuly's Avatar
gilhuly
welcome to the forum!
good luck with your car!
Old Mar 21, 2012 | 06:56 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum Jack and good luck with that problem.
To 2001 10-pcm code engine light
