need help
Old Apr 21, 2012 | 10:06 AM
redline719's Avatar
redline719
5th Gear
Default need help
i have a 92 corvette. i had to change the dash harness out due to a starter relay malfunction. got the new harness in and now the car wont start. no injector pulse or fire. i put a vats bypass module in thinking thats my problem. but it wasnt. tracked down the c12 pin at the pcm and found that it is showing a ground. been told it shouyld be 12v is this correct
Old Apr 21, 2012 | 10:12 AM
Sabre34's Avatar
Sabre34
Moderator
St. Jude Donor '06 thru '26
Welcome! Check in with the folks on the C4 forum. I bet someone there will be able to help. Good luck.
http://forums.corvetteforum.com/c4-g...discussion-34/
Old Apr 21, 2012 | 10:26 AM
FullyVetted's Avatar
FullyVetted
Welcome to the forum! Someone at "C4" will help.
Old Apr 21, 2012 | 10:27 AM
redline719's Avatar
redline719
5th Gear
will try thank you
Old Apr 21, 2012 | 03:03 PM
Wyndridge3's Avatar
Wyndridge3
Good luck with your repair. Welcome to the Forum!
Old Apr 21, 2012 | 07:58 PM
VETJAZZ's Avatar
VETJAZZ
Good luck!
Old Apr 21, 2012 | 08:07 PM
chief bob's Avatar
chief bob
Originally Posted by VETJAZZ
Good luck!
Old Apr 22, 2012 | 12:31 AM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
Welcome to the forum..
Old Apr 22, 2012 | 05:54 AM
Bills Z06's Avatar
Bills Z06
St. Jude Donor '07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18
Welcome and good luck!
Old Apr 22, 2012 | 07:00 AM
mrmtrtrnd's Avatar
mrmtrtrnd
Welcome to the Forum and good luck
Old Apr 22, 2012 | 10:25 AM
gilhuly's Avatar
gilhuly
Welcome and good luck with your car!
To need help
