ECU help
Old Feb 24, 2021 | 03:10 PM
ECurry's Avatar
ECurry
5th Gear
Default ECU help
Im brand new to this forum. I bought my first corvette 4 weeks ago, for the last 3 weeks its sat at a dealership trying to find a ECU(pt # 19210071) Please, any help in locating said "non-existent part" will really help.
Old Feb 24, 2021 | 08:01 PM
Route99's Avatar
Route99
St. Jude Donor '17 thru '26
Welcome!
Sorry to hear about your ECU problem.
I believe this is for a C6 Corvette. If I am correct with the generation, you would probably get better results posting this in the C6 General (or Tech) section since that will put your request directly in front of the members with that generation car. You might also check and see if you can use the Pontiac version. Not sure how many differences there may be internally or within the programming, but GM used the same part number for this for '05 GTOs.
A quick google search shows this at:
https://www.gmpartsproshop.com/oem-p...iABEgJcxvD_BwE
https://www.gmpartsdepot.net/oem-par...yABEgJmZ_D_BwE
Can't guarantee they are in stock, but worth a shot.
Best wishes with finding you part.
Old Feb 24, 2021 | 09:12 PM
Posted in C6 General, so this one is closed.
To ECU help
