Mountain - Prairie Colorado | Kansas | Montana | North Dakota | Nebraska | South Dakota | Utah | Wyoming
Header Install
Old Nov 16, 2006 | 01:03 PM
Cornfed's Avatar
Cornfed
My brother is flying in this weekend...I would like to run buy if possible my number is (520) 247-3092 when you have an address.
Aaron
Old Nov 16, 2006 | 01:15 PM
fright88's Avatar
fright88
3852 Norwood Drive, Unit 8, Littleton
here is the address for anyone wanting to come.
Cornfed I will call you with this when I get off work unless you post to let me know you have it. Thanks
Old Nov 16, 2006 | 01:40 PM
MattB's Avatar
MattB
I was thinking of droping by and taking a look, not sure how much help I would be. I was looking at gettting the same header setup, so very interested in the work.
What shop is this?
Old Nov 16, 2006 | 01:55 PM
fright88's Avatar
fright88
It is a custom muffler/roll cage shop that a friend of mine works at
Old Nov 16, 2006 | 03:20 PM
Cornfed's Avatar
Cornfed
I hope I can make it work. Keep my number so if plans change. If I dont make it sat. call me if you will be out finishing it off sunday.
Aaron
Old Nov 17, 2006 | 07:46 PM
EBZ0602's Avatar
EBZ0602
2015 C5 of the Year Finalist
St. Jude Donor '05-'10
My tunnel plate should be here on Thursday as well. So it is a ful LG Street system and tunnel plate. We will have a lift and an air impact gun to help losen the bolts. Any help is apreciated. We will be starting on Saturday around 3 om finishing up starting Sunday morning.
Hey EBZ0602 do you still want to help? I would love to hear what your setup sounds like if you come. BTW Goose told me to mention his name as a shameless plea for help
Hey Fright,
Where the heck is this place, this 3852 Norwood Pl., cross streets? Anything close would help.
I am plannin' on comin' by
Happy Motoring
EBZ0602
Old Nov 17, 2006 | 08:21 PM
fright88's Avatar
fright88
Looks Like Santa Fe and Norwood Drive On the west side. Looks like it is about half a mile south of 470 and Santa Fe. My number is 720 422 5104 give me a call if you have any problems
Old Nov 20, 2006 | 01:01 PM
MattB's Avatar
MattB
Sorry couldn't make it. How did the install go? Since you had a lift I assume you put the headers in from below? Or did they have to go in from the top?
Old Nov 20, 2006 | 01:12 PM
fright88's Avatar
fright88
Install went ok. I broke a valve cover bolt and we may have broken a wire on an 02 sensor or 2. I didn't have the extenders so that slowed things down. Ended up going from above with the new headers. Also we may have stripped out a hole in each manifold. But we only used 5 bolts to mount the headers,
Old Nov 21, 2006 | 12:27 PM
MattB's Avatar
MattB
I'm thinking of ordering the LG street series, so what do you think overall so far? Did you go with high flow cats or?
Old Nov 21, 2006 | 12:42 PM
fright88's Avatar
fright88
I like the headers. I would suggest asking them when you order if it comes with 02 sensor extenders. If not order some. Mine aparently didn't. Also get some of the heat protector stuff for the sensor wires. Fit is good. Also I suggest putting in the rear 02 sensors before you mount the pipe. This will keep you from twisting the wires up and damaging them. Also I would get a tunnel Plate from CCA and install it at the same time. The holes in the plate make it convienent to run the 02 wires above it so they arn't resting on the pipes. And I got cats
Old Nov 21, 2006 | 12:45 PM
fright88's Avatar
fright88
Also if you want to make your life much easier on the install buy 02 simulators and don't run rear sensors.
Old Nov 21, 2006 | 01:53 PM
  #33
HisandHerZ06's Avatar
HisandHerZ06
Did you get the SIMMS? if so, from where? if not have you had any issues/codes from the rear sensors? or did you get them turned off right away?
THX
JOE
Old Nov 21, 2006 | 02:06 PM
  #34
fright88's Avatar
fright88
I havn't gotten the sims yet. I only drove the car home because of codes I am getting from the front sensors. Nothing on the rears yet.
Old Nov 21, 2006 | 02:25 PM
  #35
HisandHerZ06
And just to make sure I am understanding this correctly, the only reason you are getting something from the fronts is cause of the 1 or 2 cut wires?
TY VERY MUCH FOR YOUR TIME AND INPUT!
JOE
Old Nov 21, 2006 | 02:28 PM
  #36
fright88's Avatar
fright88
I don't know yet why I am getting them from the front. To be honest. I know I had to splice the wires since I didn't get extenders. Any number of things could be wrong. It could be that the wires melted because I didn't secure them away from the headers well. Or the sensor could be bad. Or maybe the connectors I used to splice the wireing is bad. I won't know till this weekend at the soonest. Maybe a couple weeks because of the stupid holiday
Old Dec 7, 2006 | 08:44 PM
  #37
fright88's Avatar
fright88
Well I replaced both fronts today with extenders instead of them being spliced. No more codes for now. I am a happy man. Now I just need louder exhaust.
To Header Install
Old Dec 8, 2006 | 10:44 AM
  #38
Cornfed's Avatar
Cornfed
I knew that would fix it. Same crap happen to me when we did my last set on my 99 z28. I just forgot the extenders.
I have my LT's, off-road x-pipe, ls6 intake and she is running like a champ.
It's loud with my Borla XR1's
Old Dec 8, 2006 | 10:47 AM
  #39
fright88's Avatar
fright88
congrats. I bet she is when are you going to dyno?
Old Dec 8, 2006 | 10:55 AM
  #40
Cornfed's Avatar
Cornfed
The next dyno day.
