UPP TT Kit
honestly the kit is alright, not the best, but it works. you will probably have some issues with it at first but when all fixed it should work fine. if its just a stock motor and you are only looking to make 500-600whp then it will be fine.
CK
Joe sorry I haven't pm'ed you back. Ive been in Wyoming for work. Ill send you a pm with my number.
As for everyone else. I can honestly not find a bad thing to say about this kit. The install was spot on save for one tiny adjustment issue that upp didn't account for and that was the wider z06 tires. Which wasn't a big deal. The support behind the kit from upp is phenomenal. The tuning and e85 conversion were flawless. In fact later this summer I'm hoping to up the boost and try for over 650 rwhp......after I find and ls2/3 short block for just in case
Joe as far as daily driving, I wouldn't hesitate to do it but keep the cats the car really stinks with out them. I would change out the clutch to a stronger one. Also right now the car runs stupid hot. With the a/c on coolant temps climb to 240 and oil is right behind at 230. I am pretty sure my coolant needs to be changed and the radiator needs to be flushed to bring the temps down. I'll try that before getting a bigger radiator and a cooler thermostat installed.
CK
CK
thanks
It will be up for sale or trade soon and he is going with another turbo system.
Maybe it was smoking like a mad banshie because the oil couldn't get out of the turbos since the lines were routed upwards?
Last I spoke to him, and his tuner, I offered to drop everything I was doing that day to make a trip to Denver to get all these issues resolved, and finally get this thing straightened out. The tuner was busy and was supposed to get back with me to plan another day...this was the last that I heard from anyone.
The blanket statement of "oh china turbos" is getting a bit old, especially since NO ONE has truly had an issue with a single turbo thus far. Judging by the upward routing of the oil return lines, it's pretty clear that he's not familiar enough with turbos to be doing the installation. And I've offered to go up there, I've offered for him to come down here and bring it to me at my shop for me to remedy ((FOR FREE!). This has yet to happen, so the fact that he's still fighting issues (especially after "redesigning" the kit) is no fault but his own.
CK
CK
It is a moot point, kit is going away and I had no dog in this fight other than seeing what he had to go through from the first day he got this kit..Oh and your willingness to drop everything and come help was not always like that, there were numerous times requests went un answered.
As for the oil lines. That was done during the SECOND attempt to make this all work. I told you that on the phone. The first time I tried to put the car on the dyno, the lines on the car were the lines you supplied. I also told you before the reason I changed the lines was because the ones supplied were leaking in a couple places.
I blamed the turbos not building boost on the wastegates and went and replaced them (my own choice and my own expense). Honestly, after talking to you about the boost problem the first time, I gave the turbos the benefit of the doubt and that is why I blamed wastegates.
This second time, as you are aware, we could not build boost again. Bill tried everything you suggested and dropped the entire exhaust out of the car after you told him the problem was probably back pressure. None of the things you suggested worked. If you are still willing to stand behind these turbos then you will be doing it for someone else.
At this point I am so frustrated, I am just removing the entire kit and going a different route.
