NortheastConnecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
From: Probably talking that police officer out of giving you a summons! ========== The Beautiful Lower Hudson Valley, NY
St. Jude Donor '08-'09
Alan ... I dragged this over from the last bar. Did you compose this? I'm curious to know where these "facts" came from. How much of it do you actually believe?
Charlie
Originally Posted by asmokegars
Good is good but Bad is better!
Some stats on a top fuel car:
* One Top Fuel dragster 500 cubic-inch Hemi engine makes more horsepower
than the first 4 rows of the Daytona 500.
* Under full throttle, a dragster engine consumes 11.2 gallons of nitro
methane per second; a fully loaded 747 consumes jet fuel at the same rate with 25% less energy being produced.
* A stock Dodge Hemi V8 engine cannot produce enough power to merely drive the dragster's supercharger.
* With 3000 CFM of air being rammed in by the supercharger on overdrive, the fuel mixture is compressed into a near-solid form before ignition. Cylinders run on the verge of hydraulic lock at full throttle.
* At the stoichiometric 1.7:1 air/fuel mixture for nitro methane the flame front temperature measures 7050 degrees F.
* Nitro methane burns yellow. The spectacular white flame seen above the stacks at night is raw burning hydrogen, dissociated from atmospheric water vapor by the searing exhaust gases.
* Dual magnetos supply 44 amps to each spark plug. This is the output of an arc welder in each cylinder.
* Spark plug electrodes are totally consumed during a pass. After 1/2 way, the engine is dieseling from compression plus the glow of exhaust valves at 1400 degrees F. The engine can only be shut down by cutting the fuel flow.
* If spark momentarily fails early in the run, unburned nitro builds up in the affected cylinders and then explodes with sufficient force to blow cylinder heads off the block in pieces or split the block in half.
* Dragsters reach over 300 MPH before you have completed reading this sentence.
* In order to exceed 300 MPH in 4.5 seconds, dragsters must accelerate an average of over 4 G's. In order to reach 200 MPH well before half-track, the launch acceleration approaches 8 G's.
* Top Fuel engines turn approximately 540 revolutions from light to light!
* Including the burnout, the engine must only survive 900 revolutions under load.
* The redline is actually quite high at 9500 RPM.
* THE BOTTOM LINE: Assuming all the equipment is paid off, the crew
worked for free, & for once, NOTHING BLOWS UP, each run costs an estimated
$1,000 per second.
The current Top Fuel dragster elapsed time record is 4.428 seconds for the quarter-mile (11/12/06, Tony Schumacher). The top speed record is 336.15 MPH (541 km/h) as measured over the last 66' of the run (05/25/05, Tony Schumacher).
Putting this all into perspective:
You are driving the average $140,000 Lingenfelter twin-turbo powered
Corvette Z06. Over a mile up the road, a Top Fuel dragster is staged &
ready to launch down a quarter-mile strip as you pass. You have the
advantage of a flying start. You run the 'Vette hard up through the gears and blast across the starting line & pass the dragster at an honest 200 MPH. The 'tree' goes green for both of you at that moment.
The dragster launches & starts after you. You keep your foot down hard, but you hear an incredibly brutal whine that sears your eardrums & within 3 seconds the dragster catches & passes you. He beats you to the finish line, a quarter-mile away from where you just passed him. Think about it - from a standing start, the dragster had spotted you 200 MPH & not only caught, but nearly blasted you off the road when he passed you within a mere 1320 foot long race!
Originally Posted by Z06Voodoo
Comin up .....
How you been Charlie?
I'm doing well, thank you!! I'm really looking forward to FINALLY meeting you on Sunday!
I'm happy to see that you seem to be doing better also. Keep a positive attitude, surround yourself with friends and family and you'll continue to feel energized.
The contractor who is going to lay the last course of block and do the back fill work just had the first load of gravel delivered 20 tons worth and will bring the rest of it tomorrow. Will also bring the bobcat down to move the gravel around and do some back filling on the back side of the high foundation wall.
This is what the foundation looks like right now without the load of gravel sitting right in front of it.
From: NYC and Piscataway (depends on where work takes me)
Looks good Dona. We just found a contractor for ours. $32/square foot and that's for everything from the foundation to the electrical. Came well recommended and knows the town codes since he does a lot of local work.
Thanks.
Well once the foundation and pad are completed then we will build the garage ourselves.
