Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
Tile or Paint????
Old Mar 14, 2002 | 02:05 AM
HPdrifter's Avatar
HPdrifter
Default Re: Tile or Paint???? (pats406nitrovette)
Paint!....well not exactly! Those epoxy paints chip and peel fairly easily. You want to use a "stain" that will be absorbed by the concrete. Make sure you acid wash 1st. Good luck!
Old Mar 14, 2002 | 04:58 AM
C4 Suke's Avatar
C4 Suke
Default Re: Tile or Paint???? (HPdrifter)
That staining stuff sounds interesting... got a website for it?
Old Mar 14, 2002 | 12:28 PM
JENN NJ C5's Avatar
JENN NJ C5
Default Re: Tile or Paint???? (Rex Ruby)
Definately Tile!!! :cool:
Old Mar 14, 2002 | 01:30 PM
Z06 Fever's Avatar
Z06 Fever
Cruise-In III Veteran
Cruise-In IV Veteran
Excellent question, Rex. I'm dealing with the same issue myself...new house, now what to do to the garage floor. Anyway...either method you choose (paint or tile) make sure the concrete hasn't been sealed. That's a whole other can of worms...if it has been sealed the only thing that might stick is tile adhesive. Just MO... :crazy:
Old Mar 14, 2002 | 01:52 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
I started doing my garage 3 weeks and $2200 later I am now ready to put the tile down...should be done by Sunday. Lowes $.89 a square
Old Mar 14, 2002 | 11:14 PM
Admiral Fairway's Avatar
Admiral Fairway
I was checking the tile in the racedeck web site and registered for more information, a woman called and asked if I wanted a sample and I said sure thinking they would send a small sample, they sent a whole tile. Now if I can just get 383 more people to get sample I would be able to do the floor in the garage I am going to build. I beleive she said they where $3.84 a piece.
Old Mar 17, 2002 | 12:00 PM
vete76's Avatar
vete76
don't turn steering wheel without car in motion. and then very little. i just had 12" tile put and glue by pro. put vettes in and just messed around with the steering wheel travel, full left full right. they are coming back next week to replace a few messed up tiles. don't under estimate FRICTION!!!!
these vette tires are made to hold the road, get the pic?
fred
Old Mar 17, 2002 | 11:16 PM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Re: Tile or Paint???? (vete76)
Thanks for all the replies. After much consideration I decided to go with paint, using the U-Coat it product.
Old Mar 18, 2002 | 12:05 AM
scorp508's Avatar
scorp508
Get tiles.
Later on..... If you screw up bad on paint you'll be repainting the whole thing. If you screw up bad on tiles, you'll be replacing only the damaged ones.
Old Mar 18, 2002 | 12:15 AM
C4 Suke's Avatar
C4 Suke
That sucks about the tiles, I'd be hoping they would be strongly glued on to the point where turning the wheel wouldn't remove the tiles.
Old Mar 18, 2002 | 08:17 AM
Rex Ruby's Avatar
Rex Ruby
Default Re: (scorp508)
The U Coat it product has a lifetime guarantee :cheers:
Old Mar 18, 2002 | 07:01 PM
EricVonHa's Avatar
EricVonHa
Default Re: (Rex Ruby)
John, preparation is the key with that stuff... I put it down in a garage that was 6 years old and had to acid etch the heck out of the concrete. It was well worth the time and the effort. After 2 years of having that stuff down on the floor, I'm still immensely impressed. Oil drips, spills, and the occasional squashed bug just wipe away. Beats the heck out of trying to clean anything else! It also has not lifted from the concrete in any way.. I've jacked cars up on it, dragged a freezer across it, damn durable stuff! On another note, you can add anti-slip stuff to the mix... it's a great idea, but severely reduces the ease of cleanup! I put 2 foot wide carpet strips in between the cars to decrease the "slip and fall" factor and try not to pull the cars in or out when it's wet.. because a painted floor shows the Goodyear footprint all to well. :cheers:
Old Mar 18, 2002 | 11:55 PM
  #33
Rex Ruby's Avatar
Rex Ruby
Default Re: (EricVonHa)
Thanks Eric, I'm hoping since my concrete is pretty fresh my prep time will be reduced. Good feedback on the durability :cheers:
Old Mar 20, 2002 | 04:40 AM
  #34
Hardcorvette's Avatar
Hardcorvette
St. Jude Donor '06-'07-'08-'09-'10
I "stained" my garage floor about 4 years ago, It's holding up fairly well. However, doing the floor in a "checker" scheme would be almost out of the question with a stain. The thing about the stain is, you have to etch the concrete and do the entire floor the same color to get the best results. The stain does a great job of keeping oil and other liquids from penatrating into the concrete. I have a 3 Car garage and plan on putting the polypropylene "checker" flooring in one of the bays (over the stained floor). Kiwi Tile flooring has a tile with a special grid pattern that resists slipping and sliding, and for $300.00 you can do a 10'X10' area. :cheers:
