Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
1963 Corvette automatic problem
Old Mar 1, 2011 | 07:32 PM
Bobonthis's Avatar
Bobonthis
Default 1963 Corvette automatic problem
There is a small problem with the automatic transmission when it is cold. While driving along and approaching a stop sign and slowing down the transmission hardshifts down, by itself, as I approach the stop. Anyone have any ideas?? This is the original transmission.
thanks,
Smitts
Old Mar 1, 2011 | 08:48 PM
RoadVettes's Avatar
RoadVettes
You might get more responses if you also post this in the C1/C2 section.
Old Mar 1, 2011 | 09:15 PM
PARANORMAL's Avatar
PARANORMAL
SUPPORT AUTISM
St. Jude Donor '10, '14
48 years later and the new A6 transmissions still do the same thing.
Old Mar 2, 2011 | 07:18 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Sounds like a typical powerglide to me. Have you checked the fluid or done a tranny service?
Old Mar 3, 2011 | 09:07 AM
tomtom72's Avatar
tomtom72
St. Jude 15 Year Donor
St. Jude Donor '08 thru '26
If doing a regular trans service doesn't help at all then I would pull the valve body to see if the passages & springs & check ***** are free & clean. After that if there is still no change it could be one of the pumps?...it's been along time since and my memory stinks. Do power glides have a modulator? I can't remember!
My guess is figuring that you do trans service every two or three yrs? and that you didn't mention anything about trouble on upshifting.
If it were my car, I'd do the trans service, and while I had the pan down I'd pull the valve body right then and split it just so I could see what was going on inside it.
Tom
Old Mar 3, 2011 | 09:46 AM
Humanoid 2.0's Avatar
Humanoid 2.0
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
thanks,
Smitts
48 years old, not bad, it may be time for a rebuild
Old Mar 5, 2011 | 08:20 PM
OLD-GUY's Avatar
OLD-GUY
From: *MIDDLETOWN NY* "I thought I was an OLD-GUY, till I met Charlie"
Before you do anything check the modulator. As I remember , when they go bad they cause hard shifting ------ simple and cheep
To 1963 Corvette automatic problem
