Northeast Connecticut | Delaware | Maine | Maryland | Massachusetts | Martyrdom | New Hampshire | New Jersey | New York | Pennsylvania | Rhode Island | Vermont | West Virginia
Garage Project started!!
Old Jul 16, 2011 | 10:26 AM
Chevy Guy's Avatar
Chevy Guy
Default Garage Project started!!
Putting in a 32x24 3 car garage.
Took forever to get the permits, but the project has begun. Excavation (footing) inspection is set for Monday AM.
I hope to have the masons here next week to do the footings and foundation..
The garage will be at the end of the existing driveway.
Old Jul 16, 2011 | 10:34 AM
Eppieguy's Avatar
Eppieguy
Very cool! I Wish I had the room to at least add another garage to my current 1 car garage.
Old Jul 16, 2011 | 11:36 AM
JerzeyJoe's Avatar
JerzeyJoe
Get ready for the property tax hike. You know, all the extra police, fire, sanitation services you are are going to need. NJ just sucks!
Old Jul 27, 2011 | 06:16 PM
Chevy Guy's Avatar
Chevy Guy
Footings poured, block for foundation on site!!
Old Jul 27, 2011 | 06:40 PM
jerseydrew's Avatar
jerseydrew
make sure when you pour the slab you get it so it is rated for a lift (even if you don't plan to put one in now). put a drain in so you can wash the car indoors. and if you are going to put the epoxy coating on the floor do not let them put any coating on the floor. leave it raw and have the epoxy put on as quickly as possible.
Old Jul 27, 2011 | 06:43 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
2023 C5 of the Year Finalist - Modified
2017 C5 of Year Finalist
St. Jude Donor '09-'10-'11-'12
Looking good
Old Jul 27, 2011 | 08:00 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
some day i hope to do that, so ballpark, what does a project like that go for?
Old Jul 27, 2011 | 08:06 PM
Chevy Guy's Avatar
Chevy Guy
Stem to stern, with insulation, drywall and everything I don't think I am going be able to get out of it for under 30-35k.
I'm using engineered ceiling beams so I will have no columns inside the garage, 3 dormers, and some other expensive things.
Old Jul 27, 2011 | 08:11 PM
Chevy Guy's Avatar
Chevy Guy
Right now its a toss up between the maxjax lift and a 4 post lift. Either way, a 6 inch slab will likely get poured.
Old Jul 27, 2011 | 09:33 PM
C5 Pete's Avatar
C5 Pete
AMP Racing
Holy crap... That doesn't seem bad at all. I would have expected a bit more than that for a building like you're describing.
Gives me hope for when I finally get permission to build a 20 x 32 garage...
You've got electric/plumbing/heat in there too?
Old Jul 28, 2011 | 09:23 AM
Chevy Guy's Avatar
Chevy Guy
Im doing some parts myself like the electric, I did the plans myself, I have a friend who is helping GC and I am using his subs as well.
There is no plans for plumbing right now, but a I am running 3 service pipes from the house to the garage. One for the electric service, one for TV/internet, and one for gas if I want to do a vented forced air heater later on.
Old Jul 28, 2011 | 09:33 AM
Humanoid 2.0
not bad at all with your sweat equity. i would go for a two car one, i have a two car but it is under the house (basement garage) low ceiling and has two columns. First thing to do would be to remove the columns. Then hopefully one day build the 3 car detached with high celling for a lift.
Old Jul 28, 2011 | 10:34 AM
Eppieguy's Avatar
Eppieguy
I have a ranch house in Somerville with a 1 car garage, was thinking about putting in a 4 post lift and raising the celing to the roof so I can drive my Tahoe under the Vette which will be up in the air. Anybody have any contacts for that? Sorry to Hijack your thread but I'm jealous, I can't afford to do what you're doing.
Old Jul 28, 2011 | 11:34 AM
Chevy Guy's Avatar
Chevy Guy
Sure you can, Im not wealthy by any means.
Im going to roll this and some other house work into a refi.
Old Jul 29, 2011 | 07:49 AM
Z28TOZO6's Avatar
Z28TOZO6
If you are going to do epoxy, get a broom finish and wait at least a month before you apply the epoxy. don't dismiss radiant heat if you are going to heat it.
http://www.garagejournal.com/forum/
Old Jul 29, 2011 | 09:00 AM
Humanoid 2.0
nice, radiant heat and no insulation, someone works for the utility company
Old Jul 29, 2011 | 09:54 AM
sscamaro's Avatar
sscamaro
St. Jude Donor '07
Here is a picture of my 25X50 4 car garage built in 1992 when the house was built. Cost $14,000.
To Garage Project started!!
Old Jul 30, 2011 | 03:27 PM
Chevy Guy's Avatar
Chevy Guy
Foundation done, plaster on Monday.
Rear views:
4 Service runs, just in case.
Old Jul 30, 2011 | 08:10 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Nowadays, you'd be lucky to build an outhouse for $14K!
Old Aug 1, 2011 | 01:19 PM
Chevy Guy's Avatar
Chevy Guy
Foundation complete, plastered, amnd piers installed to help support the slab.
