Paint/Body Corvette Materials, Techniques, and How To
Moisture Removal
Old Feb 18, 2007 | 11:36 AM
stinger12's Avatar
stinger12
Default Moisture Removal
For those of you who are spraying primers, base coats and clear coats (doing their own paint job)...what type of air filter are you using to remove contaminants from the air line? What is your setup...I need to set my garage up so as to remove all the water from the air lines before I start priming.
Old Feb 18, 2007 | 11:40 AM
Durango_Boy's Avatar
Durango_Boy
Get a really good water separator, bought at places like Home Depot and Lowes. Don't skimp. Money saved here is bad, as the cheap little ones don't do much good.
Also, the paint counter at Oreilly sells little inline plastic bulbs that go on the bottom of the gun and help get more moisture out. Only good for a few hours of use...so buy a few. They are orange, and thread inline at the base of the gun.
Between the water filter at the compressor, and the filter at the gun...you should be fine.
Old Feb 18, 2007 | 12:02 PM
stinger12's Avatar
stinger12
What model number and brand is your water separator Durango_boy? How much is a quality water separator?
Old Feb 18, 2007 | 12:09 PM
Durango_Boy
I will look when I'm over at the shop next. I paid $99 for this one. Well worth it when you consider too much moisture can ruin a coat of paint.
Old Feb 18, 2007 | 12:22 PM
STINGRAY1WORD's Avatar
STINGRAY1WORD
The toilet paper one seems to work the best for my shop.
Model M-60 motorgard corporation.
Old Feb 18, 2007 | 12:43 PM
crazywelder's Avatar
crazywelder
I use 2 filters in-line from Grainger. One is a desiccant drier with replaceable media: http://www.grainger.com/Grainger/wwg...mId=1612528324
The other is a regular filter with 5 micron replaceable element. http://www.grainger.com/Grainger/wwg...mId=1611725373
Both filters cost under $100 and the replacement media and filter is about $20 for both. Mine are about 4 years old and replacement parts are still available. I replace the desiccant media and filter for every paint job. Occasionally I'll use a disposable filter at the gun. I don't use these filters for operating air tools.
Old Feb 18, 2007 | 07:05 PM
SIXFOOTER's Avatar
SIXFOOTER
I run 2 Schrader 3534-1100 water seperators on a 3564-2000 regulator. Industrial stuff, works great
Old Feb 28, 2007 | 09:30 PM
stinger12's Avatar
stinger12
bump
Old Feb 28, 2007 | 10:42 PM
dannyman's Avatar
dannyman
Once you install a water separator of whatever quality make sure your line length is sufficient for moisture to be withdrawn. Most won't work within 50 to 75 feet of the compressor. You also have a better chance of less moisture if using HVLP gun technology.
Old Feb 28, 2007 | 11:00 PM
MYBAD79's Avatar
MYBAD79
St. Jude Donor '05
Here in FL you need at least 20 foot of hose or pipe between the tank and the filter/water trap. You have to give the moisture time to condense in the line. Water traps remove water, not moisture.
In addition I use deVilbiss "snake" dessicant filters. So far so good...
Old Mar 1, 2007 | 01:03 AM
JD'S WHITE 93's Avatar
JD'S WHITE 93
plus a motorguard little orange filter at the gun and you are golden
Old Mar 1, 2007 | 10:20 AM
tehlers's Avatar
tehlers
Here in Houston what I did was: water drain and steel pipe from the compressor up to the shop ceiling, 20' across the ceiling to another drain, 20' back, down again to a 3rd drain, into a dryer and separator (TIP Tools), and finally a coupling to the hose.
TIP Tools website has some articles with suggestions on how to do a setup like this.
Tim
To Moisture Removal
