Paint/Body Corvette Materials, Techniques, and How To
Clear Coat Quick Fix ?
Old Mar 24, 2007 | 01:00 AM
c4tonezone's Avatar
c4tonezone
Default Clear Coat Quick Fix ?
Hello All,
Just wondering if there is a quick fix for clear coat peeling from the body? I am planning to have her painted in June, but there are a couple of spots that could use some touch up before then.
Thanks in advance
Old Mar 24, 2007 | 01:19 AM
Brian9's Avatar
Brian9
Originally Posted by c4tonezone
Hello All,
Thanks in advance
Try here :
http://forums.corvetteforum.com/forumdisplay.php?f=138
Old Mar 24, 2007 | 01:49 AM
BAM92's Avatar
BAM92
I used to use clear fingernail polish to stop a run in clear coat.
Old Mar 24, 2007 | 09:56 AM
arkangel81's Avatar
arkangel81
you could buy some spray can clear, but it will look like hell more than likely. if i was you i would be patient and wait for the real base clear.
Old Mar 24, 2007 | 03:36 PM
BondoKing's Avatar
BondoKing
If it is delaminating, then it will have to be removed and re done.. Only proper fix.. Any shop can easily remove peeling clear and properly prep the surface.. Does not mean the whole body will have to be stripped, but the peeling panels yes.. I guess its the top panels??
To Clear Coat Quick Fix ?
