Paint/Body Corvette Materials, Techniques, and How To
Panel Misalignment Question
Old Mar 16, 2009 | 04:50 PM
J. Scott's Avatar
J. Scott
Default Panel Misalignment Question
What would you do about this misalignment?
Leave it alone?
Build the fender up?
If so what products and procedures would you use?
Thanks,
John
Old Mar 16, 2009 | 05:13 PM
zwede's Avatar
zwede
What's the history here?
Is the door off or the surround?
If it's the door, has the skin come loose from the frame?
Has the car been fitted with a new surround? If so, break it loose and re-bond in the correct location.
I would not just slap a bunch of filler on top.
Old Mar 16, 2009 | 05:51 PM
J. Scott's Avatar
J. Scott
The door is fine. It's where the upper fender comes to a point that is the problem. It just tucks in too far right at the windshield pillar.
Old Mar 16, 2009 | 07:34 PM
zwede's Avatar
zwede
OK, in that case bust the surround loose and rebond it where it needs to be. It might seem like a lot of work, but I think you'll find it is actually quicker than to try adding filler.
Old Mar 18, 2009 | 03:44 PM
J. Scott's Avatar
J. Scott
zwede: I bought the car from Mike Flash, owner of Corvette Specialists here in Beaumont. My shop is just down the road from mine and he dropped by and showed us how to break the bond just as you suggested. We used a narrow metal putty knife like a chisel along the joint to break bond.
We made a tiny wedge from a small piece of a paint mixing stick. By adjusting the depth of the wedge into the crack of the separated bond we got the fender panel tip to lift up and align quite nicely with the edge of the door. Mike gave us the tail-end of a tube of Automix 8243 SMC/Fiberglass Repair adhesive to fill the gap. Now it will be better than new.
Thanks again for your input.
Old Mar 18, 2009 | 05:29 PM
zwede's Avatar
zwede
Excellent!
To Panel Misalignment Question
