Paint/Body Corvette Materials, Techniques, and How To
Stopping cracks?
Old Jul 31, 2009 | 10:04 PM
markids77's Avatar
markids77
Default Stopping cracks?
If the rear of my 1977 were steel, I would drill a hole in the "running" end of a crack to "stop" it, then weld, grind and fill. Is there any advantage in stop drilling a crack in SMC? Thanks!
Old Aug 3, 2009 | 10:08 PM
markids77's Avatar
markids77
I suspect if I suggested I intended to paint my car with Glidden Evermore Super Semi-Gloss house paint there would be many responses. Has no-one here an opinion on how to avoid crack propogation on a fiberglass/ SMC body panel?
Old Aug 3, 2009 | 10:23 PM
wombvette's Avatar
wombvette
Originally Posted by markids77
I suspect if I suggested I intended to paint my car with Glidden Evermore Super Semi-Gloss house paint there would be many responses. Has no-one here an opinion on how to avoid crack propagation on a fiberglass/ SMC body panel?
Cracks do not propagate in fiberglass. Its a myth. No holes needed.
Old Aug 3, 2009 | 10:29 PM
markids77's Avatar
markids77
Thank you.
Old Aug 4, 2009 | 10:45 PM
c4sailor's Avatar
c4sailor
Well, it seems everyone is right on this one.
I spoke to my boat glass guy who also builds and repairs fiberglass parts for factory "stock" race cars. He said that IF he were trying to stop a crack from running in glass, he would drill the end of it. But, he would only see the need to do that if it was going to be some time before he was going to properly repair the piece. Essentially a short term measure to keep is from getting worse until a proper repair can be made.
He agreed that after a proper repair, there is no need to have the end of the crack drilled out beforehand. He said that after the proper repair techniques are performed, the crack "no longer exists" because the repair process has rebonded all of the area that was cracked. He described the proper procedure as "V"ing out the cracked area to a width of aout twice the thickness of the piece and ending beyond both ends of the crack approximately the same distance as the V runs on each side of the crack. Then glass and resin (epoxy) the prepared area. Once done, the crack "no longer exists". Hope this is helpful.
Old Aug 4, 2009 | 11:52 PM
wombvette's Avatar
wombvette
I agree with everything but drilling the hole. Maybe on something like a big truck body where there are continuing stresses and serious vibrations there might be a small chance the crack would move, but it takes some serious continued stress to make the crack move. It is not anything like a crack in glass, where the crack will run with little or no provocation. There are bound fibers in there and they stop any propagation. Drilling a hole wont hurt anything except with a Corvette body, the hole is harder to fix than the crack. Sharp edged holes tend to show up in the finish. So I wouldn't do it.
To Stopping cracks?
