Getting ready for paint
I'm in the middle of repainting my 75.
I've almost completely stripped the paint and am looking for the best way to lay down some color.
I've stripped the paint off with a razor blade and have the hood and a fender sanded down with 40 grit.
There are several coats of non factory stuff here and there on the body so we've decided to start from scratch.
I have an old retired paint and body guy leading the way on this project but with the new paints out there I want to make sure everything goes well.
The color I've chosen is Le mans Blue Metallic Paint code, WA-933L.
What gives the deepest shine and how do you apply it?
Which primer is best and all that stuff.
Here are the pictures so far.
http://i1027.photobucket.com/albums/...oster/Hood.jpg
http://i1027.photobucket.com/albums/...ster/trunk.jpg
http://i1027.photobucket.com/albums/...ter/75side.jpg
http://i1027.photobucket.com/albums/...edfront34s.jpg
http://i1027.photobucket.com/albums/...dedrear34s.jpg
I want to have it primed on Monday the 3rd and painted on the 6th.
Any words of wisdom would be appreciated.
One more thing how much paint and how many coats is reasonable.
Same with the clear. How many coats if any?
Thank You
Ralph
We moved it into the shop and started sanding on it today with a DA and 40 grit.
We got the hood and a fender finished in 3 hours.
So at that rate 21 hours to do the rest of the car seems doable.
Of course I'm not a paint and body guy.
It is pretty well stripped down so the hidden things are pretty much in the open now. So just maybe if I can keep Tim going just maybe 3 days is doable.
Ralph
If you are that concerned about it looking perfect when it is finished, then you should not be putting a deadline on the end result - you're setting yourself up for failure. Its good to give yourself an idea of what you want to accomplish by the end of each day, setting goals for yourself. I do this for a living now, and know enough that if you want it done right, it takes a lot longer than 3 weeks to prep an entire vehicle for paint which needs to be "perfect".
All the high end restorations I have done have been stripped, bodywork and filler done, then slicksanded. Everything is blocked perfectly straight, with 2 foot durablocks, 120 grit then 180 grit. I just blocked two fenders and a trunk lid last week for a '67 mustang, and that took me a total of 8 hours, just to block the slick sand.
Once its in 180 grit, everything is given three coats of high build primer, and it is blocked again with 2 foot durablocks. Usually 320 grit, then 400 grit. Everything is then finished with 600 grit, prior to paint.
The 40 is to get through the primers.
It looks like it has 3 coats of primer on her.
Some of it was badly cracked and needed to be taken down.
The auto body guy has been out for two days now.
He's got a stone in his saliva gland. Kind of like a kidney stone and his face is swollen almost past his ear.
I'm not sure what grit paper he's planning on using but I'll show him this post to make sure were talking apples and apples here.
Again what filler do you recommend? I've heard Bondo brand shrinks? Tim has just been feathering out the little imperfections.
And what primer and paint to get the best depth to the paint?
Thanks a lot guys.
Ralph
Primers and topcoats are quite a personal preference type of thing. I like an all epoxy undercoat, Zwede uses PPG K36... who's prepping the car and what do they recommend? You'll get the best finish using whatever your painter is most comfortable spraying... our experiences mean nothing since we won't be applying the finish.
On my '71 we did the whole car in 80 grit before primer. As for primer, everyone has their favorite. We used PPG K36 (urethane 2K). The K36 was wet sanded 220, then 320 and finally 400. Scotchbrite before base took the finish to about 600 grit.
As for gaps: Any edge should be built with resin & mat for strength. You can level panel to to panel with dynaglass.
That's not a regular practice?
Hopefully I can get my guy over here tomorrow to answer some of these questions.
Ralph
Worst use of bondo I've ever seen was one of the TV-shows where they used it to fill a big gap between hood and fender!!!
Patience and a good infrared heat lamp in winter when shop temps are not constant (gets cold here early in the mountains of W. CO.) And, easy to check if your resins (epoxy, polyester, etc.) are cured properly after making a repair (especially if your replacing a Vette body panel or two) since the material applied will still get "tacky" with infra-red heat.
PS. Take your time if you want a "nice" job to last awhile.
G
He was planning on sanding the primmer with 340 and then going over it with Scotch Bright.
We agreed to step it up and finish it like is laid out on this thread.
Adjusting the doors, hood and Ect. like should be done. Thanks everyone for your input so far.
You are helping make this come out the way it should.
I priced the primer, paint and clear here in town.
Everything came to $520.00 .... ouch.
Mason B/C..... $420.00
Epoxy Primer .. 100.00
Water base paint was another hundred dollars
Color is WA933L
Is there some place that can beat this price?
And I need a 2 foot long sanding block.
The guy in town said he doesn't believe in them and doesn't stock them.
Anything else guys, please speak up.
Ralph
Epoxy primers seal really well but don't build worth a flip... will there be an intermediate step between 40 grit DA marks and primer? A "total body" skim coat of filler would scare the heck out of me... perhaps on a metal body car where the expansion/contraction is less, not on a 'glass body. My 1977 was blocked to 180 grit before primer and I still have 1.5 gallons of epoxy (3 gallons sprayable) on the car to make it straight. The car was a total Bubba'ed mess but still I wonder if $100 in primer is enough to net the "show car" look you want????
Depanding in who's base your using 340? and a scuff pad may not be your best bet. I am unaware of any paint company recommending scuff pad at final sand on primer, usually 400-600 which give a consistant finish for base to adhere.
I produce straight black Vettes with no sanding block over 16". Like most things, its the quality of the sanding, not the length of the tool...
I don't believe this included, wax and grease remover or a gallon of wash.
I do believe it was a gallon of clear and a gallon of primer.
Spraygun thanks for the heads up.
I'll check on the 2K primer.
I do not want to go cheap at all.
