Paint/Body Corvette Materials, Techniques, and How To
Body primer
Old Mar 13, 2012 | 09:29 PM
Indiana73's Avatar
Indiana73
Cruising
Default Body primer
Someone advised I should use zinc chromate primer on fiberglass. Any thoughts on this subject?
Old Mar 13, 2012 | 09:35 PM
markids77's Avatar
markids77
Don't do it. Zinc Chromate is useful as an anti-corrosion coating on steel, but fiberglass does not rust. Choose either a quality epoxy, or urethane primer (or seal with epoxy, build with urethane) and have a better base for your paint.
Old Mar 14, 2012 | 12:51 AM
Dale002's Avatar
Dale002
Old Mar 14, 2012 | 10:35 AM
929nitro's Avatar
929nitro
Originally Posted by Dale002
Old Mar 15, 2012 | 09:03 PM
padgett's Avatar
padgett
Where in Indiana
Old Mar 15, 2012 | 10:47 PM
oldalaskaman's Avatar
oldalaskaman
zinc doesnt work with alot of paints, either
Old Mar 15, 2012 | 10:56 PM
Dale002's Avatar
Dale002
Zinc Works best with acrylic and epoxy paints
Old Mar 16, 2012 | 11:45 AM
porchdog's Avatar
porchdog
epoxy needs nothing under it. the whole point of using epoxy is for adhesion and creating a barrier coat.
Old Mar 16, 2012 | 04:14 PM
Scott Marzahl's Avatar
Scott Marzahl
You got bad advise, stick with SPI epoxy for your first coat.
Old Mar 17, 2012 | 02:53 PM
Dave Tracy's Avatar
Dave Tracy
From what I have seen on this forum it has some build properties too.
To Body primer
