Paint/Body Corvette Materials, Techniques, and How To
removing primer?
Old Apr 7, 2012 | 08:41 PM
scyzoryk23's Avatar
scyzoryk23
Default removing primer?
I just started stripping paint of my vette. I am using chemical stripper (Captain Lee's Spra' Strip). It removes the paint pretty well, but not primer.
What is the best (fastest and safest), way to easily remove primer? I was using orbital sander with scotch brite pad but is very time consuming.
Any ideas?
S.
Old Apr 17, 2012 | 12:03 PM
C1-Curt's Avatar
C1-Curt
I feel your pain, for my non-gelcoat C1 some people say to use a red scotch brite pad with lacquer thinner and that did work but then some folks say that is a bad idea because the newer lacquer thinners are not so pure any longer.
I ended up with an Eastwood soda blaster to get the primer off, that was pretty easy and did not damage the glass.
Old Apr 21, 2012 | 04:49 PM
03justin's Avatar
03justin
chemical stripper is nice but dosent work all the time and its messy.i just got done stripping a 66 vette that was in bad shape. i soda blasted it since i had everthing to do it.but the eastwood blasters are reasonable and work great.
Old Apr 21, 2012 | 05:35 PM
scyzoryk23's Avatar
scyzoryk23
Which blaster did u use? and what compressor I would have to get to power it?
S.
Old Apr 21, 2012 | 05:44 PM
C1-Curt's Avatar
C1-Curt
S.
I bought a 5 HP 60 gal stand up compressor from Harbor Freight then I got the dual blaster from Eastwood. I have only used soda so far, I will do harder media on the chassis.
I have more pictures at these two links:
http://505hp.com/?p=189
http://505hp.com/?p=195
Old Apr 21, 2012 | 05:56 PM
scyzoryk23's Avatar
scyzoryk23
nice. how much was the compressor? and how much soda did u use on your project?
S.
To removing primer?
