Paint/Body Corvette Materials, Techniques, and How To
Cut and Buff?
Old Jun 27, 2012 | 08:50 PM
RR40vette's Avatar
RR40vette
Default Cut and Buff?
I need help on buffing,
I bought a fiberglass targa top and sanded a painted it with base coat and clear coat. I used PPG paint and clear, I had little specks in the paint so I wet sanded with 1000 and then 1500, I used meguiars 1 medium-cut, then follow up with meguiars 7, on my buffer I have a wool pad on the buffer and I can not get the shine back like it was before sanding
Old Jun 28, 2012 | 09:01 AM
929nitro's Avatar
929nitro
How many coats of clear did you put on. Were you seeing any red on your sand paper and what spped were you running the buffer at?
Old Jun 28, 2012 | 11:52 AM
crazywelder's Avatar
crazywelder
You still have to many fine scratches to get any gloss. Sand it to 3000 to remove the 1500 scratches. Medium Cut Cleaner is to coarse, use Meguiars Fine Cut Cleaner instead, 2 or 3 times if nessesary with a rotary buffer and the wool pad. Follow up with Meguiars #3 Machine Glaze on a orbital buffer with a foam pad 2 or 3 times. Then use Meguiars Swirl Mark Remover. Save the #7 for detail work later on.
Old Jun 30, 2012 | 09:07 AM
RR40vette's Avatar
RR40vette
i put 2 coats of clear, i did not see any red i know i did not break thru the clear yet,
running the buffer at 2,
Old Jun 30, 2012 | 09:08 AM
RR40vette's Avatar
RR40vette
3000 sand paper what stores would have that?
Old Jun 30, 2012 | 09:10 AM
RR40vette's Avatar
RR40vette
it's been about a month, can still try to buff it easy yet? or can i wet sand 400 and reclear it again
To Cut and Buff?
