Paint/Body Corvette Materials, Techniques, and How To
Glassing do's - don'ts
Old Nov 27, 2013 | 09:07 AM
YellowC5Alive's Avatar
YellowC5Alive
Good info in this thread...
Old Nov 27, 2013 | 12:36 PM
MSGT-R's Avatar
MSGT-R
Originally Posted by DUB
factory hood will be slick on the underside of the hood skin. If it is a hand laid part. The surface will be rough ( in most cases).
Also...the rivets that hold the pieces to the under structure...IF FACTORY will NOT be pop rivets....and they are actually aluminum solid rivets that have been bucked (squashed).
DUB
Wait a minute.. rivets?
There we no rivets on this hood (should there have been?)
Old Nov 27, 2013 | 05:48 PM
DUB's Avatar
DUB
YES>>> The factory style solid aluminum rivets secure the metal plates to the underside of the inner structure. These anchor plates give your bolts something to thread in to. You should have a plate for each hood hinge. One for the pop rod and there should be one for each hood latch on each side....along with one in the rear center for securing the under hood cable.
These rivets should NOT be "pop" rivets...and the heads should be flat like a dime but a bit thinner for the hood hinge plates. And if my memory serves me correctly...the rivets for the hood latches are a slightly domed rivet. I am having a brain fart on the one that holds the hood prop rod mount plate. I believe they are flat also but slightly less in diameter than the ones for the hood hinge area. I think the cable strap point is like the ones for the hood latches, I would know if they were right if I saw it...but for the life of me...after the day I had today....all I want to do it get through it.
DUB
Old Nov 28, 2013 | 10:36 AM
MSGT-R's Avatar
MSGT-R
Sorry for a difficult day.. that's what Miller Time is for!
One more question (and thanks for putting up with all of us).. so I will find NO rivets countersunk through the hood skin and glassed over?
Old Nov 28, 2013 | 04:25 PM
DUB's Avatar
DUB
Correct.
If this is a factory hood. The under structure (once removed from the outer hood panel)...will allow you to clearly see these metal plates and reinforcements. SO...they WILL NOT be glassed over or glassed into the underside of the under structure.
IF the underside of the hood panel is rough...or the inside of the under structure is rough...then this is a hand laid part. Factory panels where press molded and basically slick on both sides.
WARNING:
I seriously doubt that your hood was made out of SMC, If the hood on the underside is very slick...and the inside of the under structure is slick and has a light gray color with some dark gray streaks in it...then it is SMC...and will require using the 994 ONLY.
DUB
Old Nov 28, 2013 | 11:25 PM
MSGT-R's Avatar
MSGT-R
No, it's rough. Thanks for the clarification, my mind did an "aw-sh*t" there for a moment.
