Paint/Body Corvette Materials, Techniques, and How To
Tacking Base Coats?
Old Mar 28, 2014 | 11:10 AM
13611's Avatar
13611
Default Tacking Base Coats?
To tack or not to tack... that is the question? Is it recommended to tack cloth between base coats? Thanks, Jason
Old Mar 28, 2014 | 04:58 PM
markids77's Avatar
markids77
Paint that has "flashed off" is by no means dry, and it is possible you will mar the surface. I vote no.
Old Mar 28, 2014 | 06:09 PM
DUB's Avatar
DUB
I agree...I do not tack off my basecoats between coats. If proper equipment and environment is employed...the amount if "trash" should be minimal....HENCE...PROPER PREP...which just not mean sanding and wiping the car down ONLY.
Solid color I do at times...but metallics only if they have flashed off for a long time and I feel I need to because I see "things"....but only after I know the basecoat has flashed off for a LONG time (1+hour or more)...and that is in my paint system...i can not say it works on other paint systems
If you are wanting to tack off eh paint due to excessive overspray...you have problem in the choice of reducer, air pressure, distance, gun-set-up and other variables....the paint should not look "dusty" when you look across the top surface...at least I know my paint does not look like that. When I do tack mine off...my tack rag still looks fresh and not the color of the car. If you do tack before clear,,,,you better be PRECISE in your motions and not miss a spot...which if it is a metallic...it can actually show when you apply the clear due to this overspray dust will possibly settle differently that the paint beside it which has no overspray dust on it.
DUB
Old Mar 28, 2014 | 06:11 PM
13611's Avatar
13611
Excellent info... Thanks!!!
To Tacking Base Coats?
