76 c3 body work question
The bondo that peeled off...what is under it???? Paint/primer or bare SMC???
DUB
as far as getting the old stuff off get out a 36 grit paper on angel grinder and about a full day of dust. sorry for bad news
It is hard to read the depth and which layer is actually the bottom.
In your third photo...the one with the drivers door handle showing...there is a dark spot to the right of the handle. Is that a spot where you got down to a red oxide primer???
If what you are scraping off is a light gray hard material....it might be a polyester primer.
If you can...take some 80 grit and carefully sand down a small area until you reach the bare SMC....and then feather it back so I (we) can see how many layers you have on the car.
Depending on what you have on the car...I would wait.... because if you take a grinder to your body with 36 grit on it...it might be a bit too aggressive when a less aggressive grit sand paper will do the job without removing too much body material thickness.
Also...not knowing your skill level...going at it with a rough sandpaper with a power tool can be catastrophic. Not writing that you cant....but writing that I have repaired my fair share of Corvettes when 'someone' got a hold of it with a power tool and did so much damage due to not knowing what to do and how to do it. Thats all.
**** MY OPINION****
Also. Not meaning to **** anyone off. My philosophy is that if your need to add so much filler...that you actually entertain the use of a filler with fiberglass strands in it. Then the repair should be laminated with matt and resin so if proper techniques are employed...you reduce the chance of air in the repair which can come back and haunt you...or the use of a filler than can actually handle being applied thick and holding up. I know that the 'rule of thumb' is no more than 1/8" of filler...but in reality...that is unrealistic. With the adhesive/filler I use and my techniques...I can easily triple the 'rule of thumb' variable without any failure. Using a filler with long strands of fiberglass in it makes it really hard to mix thoroughly and make sure that you are getting all the air out...which is almost impossible unless you vacuum bag it. It is up to the person mixing and applying a long, short or chopped fiberglass strand filler. If when grinding it after it was applied...if you find a lot of air bubbles...it was not mixed and applied correctly and you are asking for trouble...in MY opinion. Which is why I use these types of fiberglass strand fillers ONLY in when repairing something that I am going to pull a mold off of and I do not care if it lasts. These types of fillers are an easy way out and made for convenience...versus lamination. They have a but are not something that I use as a repair material. But that is just me.
I use a grinder with 36 grit and I have different size pads. 8", 5", 3"and a modified holder for a 1" disc. The different size pads allow them to be used in specific areas. SO the 3" disc will get into tight curves without too much damage if you are careful and WATCHING what you are doing. The 5" in areas that are a larger curve in the body and the 8" the same way. I use the 8" on flat surfaces...such as the top of the hood and rear deck by the fuel door, below the feature line in the doors, areas of the top hood surround where they are flat...and also quarter panels and fenders...but that is beacsue I know how to move the sander when grinding.
With you being a novice in body work...do not worry. JUST REMEMBER...when you got your drivers license...and began to drive...you HOPEFULLY did not drive around with your foot to the floor ALL the time. Well...using grinder and sanders it is much the same. JUST BECAUSE they put a trigger on the tool that will allow it to run it at full power and RPM....DOES NOT mean that you HAVE TO use it that way. Being watchful of the speed and rotation of your tool and the amount of pressure you are applying on the panel is what counts. I always prefer to use a sander/grinder at a slow speed so it does not get away from me...and it also can make the sandpaper last longer because I am not heating it up. I also TRY to have the rotation of my disc/sandpaper going in a direction so that when I am grinding....what I am grinding is being directed to the floor...instead of up in the air making a cloudy work environment. In many processes..I have my shop vacuum tube set up by me so I can suck out the dust and whatever right away. I can hold the vacuum tube with one and and grind with the other when using the smaller grinders that I have that are easy to hold. Sometimes thinking ahead and taking the time to engineer something that will help you in not having a thick cloud of dust is worth it. TRUST ME....I have been doing this for long, long time and small things such as a vacuum keeping things as clean as possible will pay off. I know...sometimes it is what it is...but having a 1/2' of crap on the floor is somersetting I do not tolerate very well at all.
If you plan on grinding this stuff off. Keep a watchful eye on it and try at all cost to not grind heavily into the body. ESPECIALLY at the tops of feature lines SO...even if you leave a little bit on the panel so you can come back with a long board or a finish sander and get the rest off might be the best.
Whatever you do...do NOT freak out or get discouraged.
And any bit of advice I can give you. DO NOT look at your car as a whole when grinding. STOP...and FOCUS ON ONE PANEL....and forget about all the other stuff. By focusing on the panel you choose to work on for that day...if you do get it sanded and completed at the end of that day...you will have ONE panel down. Then pick another panel and do the same. IF...you jump around on the car and work all day on it until you are dragging your backside in your house to go to sleep.... and when you look back at it and NOTHING has been COMPLETED...that is when you might feel overwhelmed.
Also...not knowing where you are doing this or any of that. Make sure that the clothes you are wearing get put in a plastic bag and you do not go in and sit down on your couch...thus NOT brought into the house. The dusts that come off Corvettes when doing this type of work are really bad and you do not want to contaminate the environment of your living space. If you can handle it...wearing a Tyvek paint suit and all appropriate dust masks, goggles, face shields, gloves, booties for your shoes and even a respirator.
DUB
If you car is out in the environment...you really need to be careful and possibly re-think 'things'...or find a spot somewhere inside to do this.
DUB
DUB
100%.And just because you have it in a garage...if that garage is a hot box and holds moisture much like a green house...you are actually doing more damage to the car as a whole than you can imagine. This is why covering it in plastic or even a car cover is the beginning of the end if you do this regularly.
if you do not believe me...then keep doing it and wait for the tiny blisters and bubbles to show up one day...and then wonder why.
DUB
